Question about Dell Computers & Internet
I have a dell diminison 2000. The cd-rom will open ,but doesn't recognize a cd. IT say there isn't a cd-rom drive. It just disappeared? Is it possible that the eye reader went bad? It doesn't show up when I go to My computer.
    Scholar:
  • 76 Answers
If you feel comfortable opening the case, check the ribbon cable connection and make sure it is solid at the motherboard and the CD-ROM drive. First, make sure the pc is off, unplugged and you are touching metal at all times during the process. Power back on and see if that does it. If not, could be drive failure or virus problem.
Posted on Sep 09, 2009
Bios reset
If BIOS doesn't recognize CD Rom or USB, I would try updating the BIOS first. It is available at the link below. You may want to update the other drivers as well.
Dell Precision System BIOS 2 6 0 Driver Details Dell US
Apr 06, 2014 | Dell Precision 390 Workstation Tower,...
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
Feb 02, 2013 | Dell Vostro A860 Notebook
My cd rom drive does not recognize media
First check CD (bad, scratch) Change it... if not OK then
then Check Software (like media player, VLC player) re-install it
if not OK then...
Then check Cable of cd rom (loos connection) in not OK then
bring any friend's or neighbor's CD ROM for few minutes and replace... if other CDROM working ok then problem in your CD ROM
open cd rom and Check Lance (head) of CD rom... mostly lance not working in these cases.
Oct 13, 2012 | Dell Inspiron 8600 Notebook
Hi! I have a webcam easyCam Pro HO98669 Ver.1 and my computer doesn't recognise the cd with the driver. What can I do?
Ok it isn't unusual for a CD ROM or DVD ROM to not recognize a CD or DVD insert to it..Ok try this clean the lenses of your ROM using a CD or DVD cleaner disc if you have also try to wept your cd software with a clean dry soft cloth or cotton..If this will not work perhaps you need a new installation cd for your webcam.
Jul 10, 2011 | GE EasyCam Pro Webcam
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Computer doesn't recognize CD-ROM
Click on the link below and click on the "Fixit" button. It's a registry patch from Microsoft for unrecognized CD/DVD devices. Best of luck.
Greg
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
Jun 10, 2009 | Computers & Internet
CD ROM does not recognize that a disc is inserted -Dimension 2400
i think your cd rom is damaged. you can clean the cd rom lanse or you can buy a new cd rom or your cd is damaged.
Jan 28, 2009 | Dell Dimension 2400 PC Desktop
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Lite-On LTN486S issues
If you recently uninstalled or removed Easy CD Creator or DirectCD or some other CD-writing software, you might want to check out this article from microsoft http://support.microsoft.com/kb/270008/
Dec 05, 2007 | Lite On (LTN486S) Internal 48x CD-ROM...
Computers & Internet Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
