Question about Maytag MSD2454G Side by Side Refrigerator
Whirlpool icemaker. fingers constantly spin , no water
The fingers constantly spin on the ice maker. i never hear the water fill cycle engage. i put tap water in to the tray to freeze it but the fingers still continue to rotate. i also checked the line at the back of the fridge and no water was in it.
  • Maytag Master
  • 1,606 Answers
You have a bad water inlet valve behind the refrig . This is the piece that the wall water line connects to . There are 2 coils on this valve . One for the water dispensor and one for the ice maker .
Posted on Sep 26, 2009
  • 236 Answers
Turn the bale up on the IM head, to shut it off. sounds like the thermostat in the IM head is bad, or maybe the water valve. If you put water in the tray on the head and the fingers kept going I would suspect the head thermostat. change the IM head
Posted on Sep 18, 2009
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
The ice maker does not make ice anymore checked the arm was in correct position
Hello, well i would check the water line that actually fills the ice cube tray, many times these can freeze up and not allow any water into the tray. Second i would check to see if it is actually cycling, This can be done by pushing in the door switch and see if the little fingers in the tray are rotating. good luck
Dec 10, 2010 | Refrigerators
Dispenses water for drinking but not to make ice in ice machine
Your model refrigerator uses an electronic Ice Maker. You can test the Ice Maker by filling with tap water and let freeze sometimes they already have ice inside and shrinking because of defrost. If you can fill the trays with tap water and it freezes and dumps but does not refill with water the problem will be the water control valve. If ice maker does nothing and on then the Ice Maker is the problem. Try that first and let me know what you find, Sea Breeze
Feb 18, 2010 | GE GSS25JFM Side by Side Refrigerator
Ice maker not working
Try filling the ice maker with tap water and let it freeze. If the ice maker cycles and dumps the cubes and then does not refill the dual water valve on rear of the refrigerator for the ice maker fill side is defective, if nothing happens when you pour the water in the trays then most likely the ice maker needs a new thermostat. I'll come back hopefully with photos and links. Sea Breeze
Oct 17, 2009 | Frigidaire FRS26H5AS Side by Side...
Icemaker stopped making ice.
If not filling with water the water control valve is most likely the problem. Pour tap water into tray let freeze and if it cycles and dumps the ice then the water control valve is the problem. If the ice maker does nothing trying this the the ice maker is most likely the problem, I need your model number to confirm which type ice maker you have because some do not have replacement parts. The model number of your Whirlpool Refrigerator, Thanks Sea Breeze
Oct 02, 2009 | Whirlpool Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
ICE MAKER INOP
Check the water control valve on back and bottom of refrigerator. One side is for the dispenser and the other side is for the ice maker. When the ice maker begins a cycle the thermostat inside the ice maker begins to warm the bottom with a heating element to allow the ice to move freely and then dump into the container beside it. As the cycle reaches its final resting place a limit switch is pressed inside the ice maker to refill with water and start the process again. So if the water valve does not open and the tray remains empty and the ice maker will try to cycle again if the thermostat says that it is cold enough again. Check your model number again and I will try to get you some drawings. The number looks good but can't seem to pull it up. Let me know what you see and find. Try filling the tray with tap water and see if it will cycle after freezing. Thanks, Sea Breeze
May 20, 2009 | GE Refrigerators
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Maytag MSD2454G Side by Side Refrigerator Logo
102 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
