Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
I have insufficent pressure on the high side, it like 800 when it should be 2200.
    Sergeant:
  • 384 Answers
Clean out the nozzle with a small diameter wire.
Posted on Sep 09, 2009
Add fREON bird low
H stands for High Pressure and the L stand for Low Pressure.
The A/C system is split into two sides, a high pressure side and a low pressure side. An AC compressor is basically a pump, so it has to have an intake side (low pressure side) and a discharge side (high pressure side).
Sep 18, 2013 | 2003 Suzuki Aerio
Rich, I mistakeny typed the first inquiry incorrectly. Thanks for the original answer. I reposted the question in it's correct form
The small line is your high pressure liquid line unless it is a heat pump running on heat then it is reversed and it does not suppose to be insulated.
Oct 25, 2011 | Heating & Cooling
Locate high and low side of a/c system on 1995 isuzu trooper
High pressure side is smaller tube than the low pressure side. Also, there should be service points on both sides with caps over them, marked L for low pressure and H for high pressure.
Jun 12, 2011 | 1995 Isuzu Trooper
Temp off air coming out of register 74 degrees suction line temp is 42 degrees but high side line isnt warm dont look like it is wanting to take freon either compressor is running new system low side is...
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
May 11, 2011 | Goodman Heating & Cooling
What does "sulfated Condition" mean
The battery is dry. It has insufficent acid in the battery
Feb 26, 2011 | Vector Black And Decker High Frequency...
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Good spark -- fuel supply line has fuel -- will not start -- either sprayed into air intake -- car immediately fires -- why are cylinders not getting fuel?
possibly a bad pressure regulator or injector module not letting the injectors fire. check out both more than likely the injectors are not firing.
Aug 30, 2009 | 1989 Buick Riviera
I cannot differentiate between the low pressure and high pressure
This is a little A/C 101. Follow the A/C lines. All A/C systems have a high pressure side and a low pressure side. The high pressure side is from the compressor to the condenser coil on the front of the vehicle to the evaporator coil in the dash. At the expansion valve in the evaporator the pressure drops. At the expansion valve the refrigerant changes from a liquid to a gas. This provides the cooling. The low pressure side is from the evaporator back to the compressor. Usually the high pressure lines are smaller than the low pressure (suction) lines.
Jun 13, 2009 | 2003 Chevrolet Silverado 1500
R134 pressure
do not try to maesure high side pressure - no need.
low side pressure should be about zero ie ambient pressure of the air around us.
if in a partial vacuum, indicates a blockage in sealed system or short of gas.
if pressure well above zero, indicates compressor failure
Sep 09, 2008 | Amana SXD524VW Side by Side Refrigerator
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
101 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
