Using the extended memory feature via SD card
Please help me, I'm going crazy with my MP3 player. I have no idea how to get music to save to my SD card, it always defaults to the devices memory.
  • bruntong Feb 22, 2008
    Music will not record to the micro SD card on the sansa c 250
  • omahared1969 Aug 25, 2008
    I cant download music to my memory card, Music that I already have down loaded to mps
With my Joybee 130, the SD card appears as a separate drive when you plug the player in. In Media Player, I have to select the correct storage device and set up the transfer by playlist using Tools Options Device, then Sync the device. If you are using Explorer to copy files to your device, again, check to see if a second drive letter appears in the directory tree. Good luck
Posted on Dec 27, 2007
Is there a manual for the lexar mp3 mda256-100? My daughter gave me one and it has more features that I would like to use.
Is it packed when your daughter gave you the mp3? If so, there should be a manual in the box. Or download it from Internet.
Yes, music can be saved to the SD card. In fact generic sd is okay.
electronics wholesale
Nov 10, 2011 | Lexar MDA256-100 MP3 Player
I Keep getting "playback error" "format not supported" on lgcf360
Hello All, I think I may have a solution for the 'Playback Error'problem with the LG CF360. Below, I have put the steps that caused my phone tohave the error and then the steps I took to get rid of the error. Firstly, my CF 360 worked well for hours of playing songswithout any error. Then, after I did the following steps, the error happenedover and over.
  • I pushed a mp3 ring tone via blue tooth to the phone with the SD card in. It saved the ring tone in the SD card, but I wanted it on the phone in case the card was out, it would still ring.
  • I took out the SD card and pushed the same file to the phone, so it would save on the phone and not the SD card.
  • I also pushed another mp3 to the phone.
Then, the "Playback error" happened intermittently every fewminutes. This may have been caused by either
  1. The phone's library of mp3's being corrupted because of the same file in two locations, or
  2. The phone's physical memory getting too low to effectively play music.
Here are the steps I took that got rid of the error.
  • Delete the duplicate mp3 from the SD card
  • Move all music mp3's to the SD card and off of the phone.
  • Move some pictures to the SD and off of the phone.
  • Shut off phone
  • Take out SD card.
  • Turn on phone and try to play a playlist of songs that were on the SD card (causes the phone not find the file and update the music library)
  • Put in SD card while the phone is on. (causes the phone to re-build the music library).
After I did this, I have played mp3's for hours without anyerrors at all, just like before. Either I had too much stuff on the phone orthe music library was not correct causing the crash. I hope it helps. Mike
Aug 14, 2009 | LG CF360 Cell Phone
MP3 wont play in my LGkeybo
I have a Keybo 2 phone so I assume the procedure is the same for the first generation Keybo.
1) First of all, only MP3 format works, period. Don't waste time trying to load WMA or any other music format.
2) Get a micro SD card as this opens up other features of the media functions
3) Using the USB cable, connect your phone to the computer and there should be 2 file browsers that will show up: one for the internal memory and the other for the external memory (micro SD).
4) On the external memory browsing window you should find a MY MUSIC folder. Copy all your MP3 music files into this folder.
5) Unplug the USB cable and open your phone's music player. It will detect the new songs and build update the library.
There you go, you're all set! It took me a couple of hours of searching and tryouts but this works every time. Good listening!
Jan 18, 2009 | LG 10X DVD IDE 452000078
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Downloading
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was!
:-) Good Luck!
May 22, 2008 | GPX MW3836 MP3 Player
Mp3 player
:-) Good Luck!
May 02, 2008 | GPX MW3836 MP3 Player
Download music
:-) Good Luck!
Jan 18, 2008 | GPX MW3836 MP3 Player
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
196 people viewed this question
 Grubhead
Grubhead
