Question WHAT HIBERNATE ON THE LAPTOP
  • 4 Answers
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Posted on Sep 09, 2009
Hi how r u plz tell me my laptop ibm t41 there have problem when i on my laptop the screen is come black and when i press the hibernation botten 2 or 4 time then it work ok what is the problem tell me plz
Posted on Sep 27, 2010
  • 298 Answers
Hybernate puts your system into a almost off mode, it saves everything that you were doing to disk and it can be turned back on to its exact state at a later time.
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
My laptop doesnot come back from hybernation. I have xp on my Toshiba laptop.
Common problem with a lot of laptops.
I recommend you shut it down as opposed to let it hibernate or just turn off hibernation
Start... Control panel.... Power options... Hibernate ... uncheck the box "Enable Hibernate"
Jan 03, 2011 | Computers & Internet
The hibernate option is not getting activated.what should i do?
In window xp follow this steps to activate hibernate mode
go to start then setting and select control panel, then go to and performance maintenance, select power options, then power options property appear you can see 3 tab is hibernate there from down check enable hibernate, press apply then go to advanced tab on the same window, when i press the power button on my computer select hibernate there then press ok,
now try to press the power button on your laptop to go to hibernate mode
Regards
manish
Mar 24, 2010 | Dell Inspiron 6400 Notebook
Packard Bell laptop switch off instead of hibernate
This is done via Windows Control Panel -> Hardware and Sound -> "Power options" -> "Choose what closing the lid does" and select 'Hibernate' instead of 'shut down' for both 'On battery' and 'Plug-in' power.
Let me know how you go!
Dec 30, 2009 | Computers & Internet
My hp 530 laptop with windows vista doesn't sleep or hibernate
Sleep/hibernate is a function of the video driver. so download and install the latest video driver from hp.com
Dec 13, 2008 | Computers & Internet
Hibernate
Laptops have a ACPI power management piece of hardware on the motherboard. Sounds like this driver is corrupt or missing. Go to Acers website and look for drivers and find the one that says ACPI or even chipset drivers may have it.
Nov 02, 2008 | Acer Aspire 5610-4648 Notebook
Hibernate
try this
1. Click Start , type command in the Start Search box, right-click Command Prompt in the Programs list, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue
2.At the command prompt, type powercfg /hibernate on.
Oct 07, 2008 | Compaq Presario R3000Z Notebook
Laptop cannot 'hibernate"
Delete the file hiberfil.sys at C:
The file is likely corrupted.
http://www.mydigitallife.info/2007/10/25/how-to-delete-and-remove-hiberfilsys-hibernation-file-in-windows-xp-and-vista/
Sep 16, 2008 | Acer Aspire 4520-5582 Notebook
My laptop wont hibernate!
Typically this indicates a problem with a particular piece of hardware or its driver that is not cooperating when windows tries to hibernate. Do you have anything new attached to the system? If so, try unplugging it, rebooting, and see if it cooperates then. Also, have you checked the windows event log to see if windows reports any particular errors when trying to hibernate?
Sep 02, 2007 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
