Question about Sport & Outdoor - Others
I may have cable problems on my pop-up.
I have an older pop-up camper made by Skamper. The cable system is getting harder to operate, and don't want to have a problem raising or lowering top while far away from home on a camping trip. Is there a distributor for cable repair kits for a Skamper pop-up? Also a manual available?
5 Suggested Answers
  • 13433 Answers
SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Posted on Oct 26, 2008
  • 68 Answers
SOURCE: Broken cables to lift roof
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
This should help, Pictorial and instructions. Also parts available.
Thanks for using Fixya
Jerry
Posted on Mar 26, 2009
SOURCE: How do I replace my broken cabel in my '94 Skamper
How do I replace my broken cabel or coil in my '94 Skamper pop up camper. The cabel is bent on the right rear corner, It is twested and bent and I have tried to repair it but keeps getting twested and re-bent. My question is if I can't replace it or repair it can I cut it off andraise three corners and left the right corner and prop it up with a bar support.
Posted on Sep 08, 2009
SOURCE: 84 Starcraft Stardust pop up camper repair/parts manual
I have a stardust camper which I converted to a utility trailer, what do you need, I can send you the manuals and paper work I have, the other stuff might not be worth the shipping?
Posted on Aug 23, 2010
Owners manual for Aero Voyager 2003 pop up camper
Sorry we don't have access to this manual.
Mar 13, 2012 | Cars & Trucks
I lost my restore disks. How can I find new ones?
The older the laptop the harder it is going to be to find replacement copies. However, most of the time you don't need them if you can get a copy of the Operating System and the driver files.
Apr 24, 2011 | HP Pavilion dv1130us PC Notebook
Broken Cable on Pop-up trailer need help
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Sep 06, 2009 | Sport & Outdoor - Others
Looking for 1984 21' pop up starmaster cables
McMaster.com. or look up stainless steel aircraft cable. You can get plain, stainless and plastic coated. Nicopress fittings and tools if needed. Don;t let the aircraft part fool you, it's reasonable. I have also bought it at an Ace Hardware, and a boating supply store (boat yard supply). All the same cable.
Regards, --W/D--
Aug 06, 2009 | Star Sport & Outdoor - Others
How do I replace my broken cabel in my '94 Skamper pop up camper?
Jul 17, 2009 | Sport & Outdoor - Others
Pop up Camper will not raise up when cranked
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
Jun 04, 2009 | Arc'Teryx Rock & Ice Climbing
Hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
May 25, 2009 | Coleman Campers Grill
Pop-up camper lights all turn on when tow-vehicle lights are on
FIRST, make sure white wire of camper is grounded to the frame of tow-vehicle. Temporarily use a jumper-cable frame-to-frame. Then apply 12volts individually to each of the three circuits to the camper. Assuming a 4-wire flat connector -- brown wire is for marker lamps; yellow is left brake/turn; green is right brake/turn
May 21, 2009 | Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
How to tighten cable on pop up camper
Oct 26, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Sport & Outdoor - Others Logo
79 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
