TV turnes off for no reason
After about an hour of playing, the TV will turn off. It will power back on as soon as you turn it back on. Sometimes it will stay on for two or three minutes, and sometimes an hour or longer. Any ideas?
  • 8,457 Answers
Ur high voltage intermitionly causing the prob.
The FBT,the flyback transformer is cold solder or slowly dying just not dead yet.The big block of plastic with a red wire with a cap hook up to ur CRT(tv tube).That the cause.
Posted on Sep 09, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
When I turn the tv on sometimes it will come on and play for hours other times it will go black but the pip still works, then the full screen picture will come back on, other times when I try to turn it on...
ok , think about this. when it can come on and play that mean all the components are in good working conditions.
the problem is that there is bad connections which disconnect when it become hot!
Sep 14, 2009 | Televison & Video
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
TV turns off. Sometimes it turns off soon after turning it on and other times it turns off after an hour or two; It turns off at random. I find myself having to unplug it from the outlet and reconnecting...
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Jul 01, 2008 | TruTech PLV1615T 15 in. LCD Television
No power
That day while you were out it might have rained or lost total power in the house and your TV might have suffer what is call power surge or lighting damage ,those two thing do a lot of damage to any electronic equipment,you need to get a qualified service technician to diagnose the problem.Sometimes there is no reason and the tv's just fail.Good luck.
Sep 18, 2006 | JVC AV-32980 32" TV
Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Jan 29, 2006 | Toshiba 32A43 32" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
