Question about Lexmark X1270 All-In-One InkJet Printer
Printer I have a x1270 printer. which i set up on the computer. but when i try to print. It wont.coud you give me a solution to my problem.
ginko
  • 19396 Answers
SOURCE: lexmark x1270
Try downloading the drivers and software from : http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=227:5:0:537:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Cheers
Posted on Feb 14, 2008
toddg
  • 171 Answers
SOURCE: Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Posted on Sep 24, 2008
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
  • 461 Answers
SOURCE: Printing document from computer
Regardless of the application, open the document, click File, then click Print and select the printer. If the printer is not listed it needs to be installed on the computer.
Posted on Dec 07, 2008
acdr
  • 1913 Answers
SOURCE: Lexmark X1270 my printer will not respond
reconnect usb cable again.also check proper driver installed.
http://www.lostmydrivers.com/printers-drivers/lexmark/lexmark-x1270-all-in-one-printer-driver-v1.0.11.0-windows-2000-xp-server-2003.html
Posted on Jan 07, 2009
Printer write as javascipt
I presume you are using the Lexmark X1270 inkjet printer since you're posting under this model.
It could be that the printer driver on your computer is not properly installed. Try to uninstall your existing printer driver then reinstall using the X1270 driver on the Lexmark website. To uninstall, from your computer, go to Start menu > Programs > Lexmark X1200 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
When the computer turns on, please visit the Lexmark website to download and install the Lexmark X1270 XP Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Try to print your document again to verify that the problem is fixed now.
Nov 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X1270 Printer is only printing in colour ......wont print in black
It could be that your black cartridge needs cleaning or is not properly seated in the carrier. Open the printer cover and reseat the black cartridge. Close the printer cover. Open Lexmark Solution Center on your computer. Go to Maintenance tab and select Clean to fix horizontal lines. Your printer will then print a test page forcing ink through the nozzles and clean them.
May 31, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x 1270 all- in-ine inkjet will not
Ok! there is two methods ok! turn off your printer and restart your computer and make sure that the computer recognizes your printer and once thats done make sure that once recognize you could install the drivers to your printer. Try that if not hit me back...
Mar 26, 2010 | Lexmark X1270 All-In-One InkJet Printer
How do I install the OCR application?
I guess you are not selecting a printer while you giving print command.
Click on Print, A rectangle box opens with options, on top you will see name, see it shows your printer name " Lexmark X1270 and not microsoft office document writer.
If correct printer is selected then it wont save an image or word file, it will perfectly print your document.
Cheers
Nov 06, 2009 | Lexmark X1270 All-In-One InkJet Printer
2 document pending for print.i coud not print now.
hmm simply just click printer icon and cancel all the docs for printing then again give the print command and your papers will print
Mar 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Will not Print
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer not printing
ok..disconnect from computer..try restarting with hard power down(unplug from wall)..
turn on again..try to do a test page from front panel
Aug 18, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
