Question about Broksonic DRVCR900 DVD Recorder/VCR
It won't recognize some of the dvd that was burned
It won't recognize some dvd's that was burned on this same unit. keep getting error code C-104 incorrect disc.
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
SOURCE: Disc read problems....
The problem may lie with the format of the disk, is the disk a
DVD-R -, or a DVD-R+?. if it was a bought DVD, it may be the wrong regon (i dont know how to spell the aforesaid word), a bad copy, a dirty reader, a dusty DVD, or your player.
thats all i can say
Posted on Mar 10, 2008
SOURCE: Will not recognize dvd discs
Welcome to the sansui got ripped off club...c-104 is more common than rain in washington...no disc? thats what the unit finally displays when it has taken a thorough dump. Give your sansui to someone you don't like, and go buy a panasonic.
Posted on May 11, 2008
SOURCE: incorrect disc c 104
Hello tvergus
Check your disc if it's clean. If yes, check also its compatibility with your DVD player. Some DVD players are choosy also. You may also clean your DVD player using the recommended cleaner.
Posted on May 16, 2009
  • 132 Answers
SOURCE: My DVD player keeps saying "incorrect disc" when I
cd cleaner may help. lazers find it tough to read discs with dust on it.
Posted on Dec 30, 2010
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
Apr 02, 2013 | Acer Aspire 53362524 Intel Celeron 900 2....
Emachines e725 dvd won't burn default factory disks. error:0x207
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/unable-to-burn-factory-default-restore-disks-code/a77bddc9-d41f-4f85-a206-58db1dee77a4
Nov 05, 2012 | Computers & Internet
Will not read DVD's
Likely the alignment or laser.
The Sansui is a $50 DVD, in my opinion, you would be best served to replace the unit with a similarly priced unit.
--Mark
http://www.marksatterfield.com
Feb 10, 2009 | Sansui VRDVD4005 DVD Player/VCR
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 will record DVDs provided they are DVD-R NOT DVD+R. I have one of these for 3 going on 4 years and I took it apart and cleaned the dust off the magnetic hub and that worked for awhile but (2-3 months) now I'm having trouble finalizing again. Someone on this site said it needs 8x NOT 16x disks ... 'cause it's an older unit ... I'm checking it out in the users manuel.
magicbbs
Oct 19, 2008 | Sansui VRDVD4005 DVD Player/VCR
Dec 29, 2007 | Sansui VRDVD4005 DVD Player/VCR
Broksonic DRVCR900 DVD Recorder/VCR Logo
27 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
