Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodar easyshare 5100 printer wont print despite having ink it stil wont print anythng all i get is black lines !!
CoaI have just added new ink and the colors do not print correctly and there is no black ink printing. What is the problem with my printer
Black printer ink in Kodak Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 25, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print in black. I do not use the Kodak EasyShare 5100 very often, and the black ink will not print, despite fitting a new cartridge.
Try reinstalling the software. If you are using the disc it came with make sure you check web installation. Do not plug in printer until told to do so.
Feb 26, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Can I only use a black ink cartridge? i ran out
Before you print through the computer, select Print, then select "Properties". Select the "Color" tab and in there, select "Print in Greyscale"
This works for most color printers I have used where the color ink is gone.
Hope this helped.
Len
Aug 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black wont print
THE BLACK INK CART. either dried or end , make a test , take out the cartridge and get a piece of paper towel and pass it gently
where the ink is .hope this helpful AJ
May 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have a Kodak 5100 all in one printer, I just replaced the black ink cartridge and now it won't print anything but come black lines. How can I fix this?
hi there,
you have to check some of the possible cause why the print won't print:
  • make sure that the ink was properly seated on the carriage.
  • do a printer head cleaning. do deep printer head cleaning using the printer utilities installed on your PC.
just let me know for further clarification, k.
May 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Kodak Easyshare 5300 Will not print black ink
They overnighted a new printer head and free ink. We already recieved it. AMAZING. Thank you Kodak. They are awesome.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer not printing black ink
Contact Kodak with your problem. The problem is in the print head. Kodak will send you a new print head free, then follow the instructions that are inclosed to change the print head. DO NOT TRY TO CHANGE IT WITHOUT READING THE INSTRUCTIONS. You may damage the new head and they will not replace it a second time for free.
Dec 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing
Dear Audley,
It seems , Ink cartridege's head gone dry & Cappileries gone blocked , best solution is you can replace the ink cartrideges.
Regards
Sep 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer will not work
I have a kodak 5100 it worked fine until I changed the black ink then it would only print 1 line called kodak yesterday at 9 am and they said they would send new printer head and new ink..it arrived this am and now printer is working fine. I think they know there is a big problem and need to do a recall.Did not think they would act so fast but they did.
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
