Question about Garden
Remington X0089-05 pushbutton oiling?
I have a Remington ...089-05 model. Manual says press oiler cap for "pushbutton" oiling. The plain screw cap does nothing but close the oil reservoir. Am I missing something?
    President:
  • 2,220 Answers
I cannot find an owner's manual with the model number you supplied. I suspect it is actually a serial number.
I did find a manual with this step (Page 5 "OILING SAW CHAIN")
here:
http://dl.owneriq.net/f/f2821a14-608e-71b4-81fc-1a62bb3d6bfd.pdf
If you purchased this new the reference is probably for an earlier model and should not be there. If gifted to you used or purchased it used the cap may have been replaced.
I suggest you contact the manufacturer here:
Remington.com
http://www.remingtonpowertools.com/find_manual.cgi
And ask for clarification of the manual or a source for the correct oil reservoir cap. HTH
Lou
If you contact Remington please provide EVERY number that appears anywhere on this item.
Posted on Sep 10, 2009
Old Remington SL4 Automatic Oiler
Found a website with all the equivilant homelite XL12 illustrated parts lists. You may need to look down the list to find the exact match.
Jul 27, 2013 | Remington Garden
Homelite com
Homelite XL12 parts manuals
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
Doesthis thing need oil or some other liquid type
The bar and chain require bar oil (only) to be placed in the capped tank. The motor itself is air cooled, and should be blown out with compressed air often to remove the accumulated sawdust. Make sure the chain is tightened just enough to prevent the lower part of the chain from drooping from the bar and can be turned by hand. Make sure to keep the chain teeth sharp by properly filing for best cutting. Test the chain oil pump operation by running the saw with the chain tip near a piece of cardboard--it should throw off a thin line of oil after a moment or two of running. Hope this helps!
Apr 05, 2010 | Remington Electric Chain Saw
I need to know where I can buy part 107512-01 (oil cap) for Remington Pole Saw.
Masterparts has one here:
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=107512-03
Apr 01, 2010 | Remington Polesaw Wizard
Oil leak on Remington electric chain saw model #111174-01
Use the following IPL as a disassembly/reasembly guide and to determine which oiler part has failed.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107625-02/107625-01-EL-8-BD.pdf
Once identified attempt to find a replacement here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Remington is no longer in production. Eventually eBay will be the sole replacement part source.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Remington 16" Electric Chain Saw
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH Lou
Jan 23, 2010 | Remington 16" Electric Chain Saw
What type of bar oil do I put into a Remington electric chainsaw? (no manual, model #107624-01 ,16"bar
From page 9 of your manual:
FILLING OIL TANK
  1. Remove oil cap.
Like so much of what MrFixIt posts his opinion is based on BS. He can never take the time needed to provide any answer that actually requires thought or research!!!
Use bar oil available at any home center or hardware.
You can download your manual here:
Remington.com
HTH
Lou
If you did not rate his answer please give it the NOT HELPFUL rating it deserves.
Dec 31, 2009 | Remington 16" Electric Chain Saw
Remington mighty mite chain saw
hi Wayne
Oiling has nothing to do with compression.It has conection only with engine rotation(rpm).More rpm results more oil and viceverse.Check the oil filter,the oil line,the holes from the bar,the oiler,the wormgear and the oil hose.
wish you all the best savumihai71
May 14, 2008 | Remington Polesaw Wizard
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
