Question about Music
Changing strings on a pacific electric guitar
    Problem Solver:
  • 10 Answers
Www.raeguitars.com has a wicked guide that covers all kinds of things...including changing strings. I would highly recommend to everyone who owns a guitar!
Posted on Nov 30, 2009
    President:
  • 1,138 Answers
Try here:http://www.yamaha.co.jp/manual/english/result.php?div_code=guitar
Posted on Sep 11, 2009
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I bought a Hagstrom Ultra Swede which sounded very nice when I first bought it but after 3 months I seem to have alot of tuning problems with it. It has been intonated twice and a new set of heavier...
Considerations:
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
Oct 18, 2010 | Hagstrom Swede Electric Guitar Natural...
I don't know how to change the strings on my shector 006 deluxe, any help please? ive had the guitar a few months now and think it is due a change in strings, however i feel unsure about uncsreweing parts...
There are instructions on YouTube.com regarding changing strings on guitars. The video illustrations are much better than trying to write in words the proceedure.
Apr 23, 2010 | Schecter 006 Deluxe Electric Guitar...
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
My guitar string is broken but it's on a electric guitar. please help me because my lesson is in october
does that guitar still has warranty? where did you bought it? try to go to music repair shop and consult it. they will help you bigtime. promise. i hope i helped you even a bit. thanx
Sep 13, 2009 | Yamaha Electric Guitar
Which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Feb 26, 2009 | Washburn X10 Electric Guitar
Dean razorback DB problem
If the neck of the guitar is a bolt on neck (their will be a plate holding the neck onto the body of the guitar with several screws) then this is typical. Some strings will give off small vibrations. Nothing is wrong with the guitar, usually with a string change or with time the tone will fade as the strings change to the shape.
Hope this helps,
-Aaron C.
Jan 25, 2009 | Dean Razorback Db Electric Guitar
Music Logo
78 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
