Question about Nikon N60 35mm SLR Camera
Nikon n60-autofocus Hoping that someone here can help. Seems that I am without auto focus...when depressing the button to focus...I just hear a fast tap tap tap....and there is not any movement. I have checked the placement of the lense and all looks well. N60 stopped auto focusing, no longer takes photos
Replace the battery maybe weak.
Posted on Dec 28, 2007
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Jun 12, 2016 | Nikon D Cameras
Autofocus problem
Does this problem still exist when you have the shutter pressed halfway down?
Regards,
Worldvet
Jun 15, 2008 | Nikon D40x Digital Camera
Does not autofocus
Assuming you've made sure the auto-focus is turned on on both the lens and the camera, remove the lens, turn off the camera. Remove the battery. Wait about a minute. Put the lens back on, turn the camera back on . It's a computer basically. Sometimes it crashes. I've had this happen to me a few times.
Mar 13, 2012 | Nikon D90 Digital Camera with 18-105mm...
Do the old AF lenses for the Nikon N60 SLR fit the new DSLR cameras
Hi ericm675, Yes they will. What you run into is were one uses a auto focus lens on a newer digital such as a D40. Some of the new digital cameras do not have the drive gear to turn the autofocus on the lens. Those newer cameras use electronics. Look on your camera lens mount at 7:00 you will see the drive pin. Look on your old autofocus lens you should see a slot where that pin fits. Hope this helps you.
Aug 22, 2010 | Nikon N60 35mm SLR Camera
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Nov 11, 2005 | Nikon F4s 35mm SLR Camera
Nikon N60 35mm SLR Camera Logo
117 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
