Question about Lexmark X2600 InkJet Printer
I have a lexmark x2600 and it will not print in color.
  • gerand177 May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    5
SOURCE: cant install lexmark x2600 on windows vista
I just installed printer on laptop vista,printed the alignment sheet and scanned for alignment but when the test page is requested to print, it won't print, it shows the document is been deleted
Posted on Feb 06, 2009
frankzjm
  • 191 Answers
SOURCE: Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
  • 14 Answers
SOURCE: my printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Posted on Apr 24, 2009
SOURCE: need product key code for lexmark X2600
For what ? The software installation? I don't understand?
Go to Lexmark's website and get another copy - No key required
Here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on May 01, 2009
Daniel S
  • 4323 Answers
SOURCE: what are proceedures for replacing print
Hi
To replace the cartrdige for your Lexmark X2600 printer you'll need to to turn on the printer.
Now, raise the scanner unit. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving. Now look for the empty cartridge in the carriage on the right. Replace it with a new cartridge by simply pulling it straight up. Now close the scanner cover and restart the printer. Now you are good to go. Daniel Scott.
Posted on Jun 11, 2010
Can't print in black ink only
Give it a try by removing the empty color cartridge!!!!!
May 11, 2013 | Lexmark X2600 InkJet Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
Lexmark x2600 printer; color looks great for 1st 2 inches of printing then changes; green went blue, yellow went white, red to purple.
Your cartridges may need to be cleaned. Open the Lexmark Solution Center and select Clean to fix horizontal streaks. This will force ink out through the cartridge nozzles, cleaning it from dirts and clogs. This will improve print quality on your printer. Also, make sure you are using genuine Lexmark cartridges to achieve high quality results.
Apr 08, 2011 | Lexmark X2600 InkJet Printer
My lexmark x2600 printer wont print where can i get a free manual?
Navigate into this site, you can download free user manual of lexmark x2600..
http://www.retrevo.com/support/Lexmark-X2600-Multifunction-Printers-manual/id/17669bh333/t/2/
Thanks,
Nov 20, 2010 | Lexmark C533DN InkJet Printer
Can i wirelessly connect my Lexmark X2600 printer to my Toshiba Laptop
I regret to inform you that the Lexmark X2600 is a USB based printer, however, you can use a wireless print server to turn this printer into a wireless one. You can check the internet on how wireless print servers work. Thanks.
Aug 11, 2010 | Lexmark X2600 InkJet Printer
How do I get my lexmark x2600 ink cartridges to work
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Mar 02, 2009 | Lexmark X2600 InkJet Printer
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!! http://search.lexmark.com/printer/US/en/12L1685.html
Dec 17, 2008 | Lexmark X2500 All-In-One Printer
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
My Lexmark X2600 printer will not print. A notice keeps showing up on the screen, telling me that the color cartriage needs replaced before it can print. I just replaced the color cartriage. Can you help...
go to the printer properties option.their go to lexmark solution center .in that option there is a option to get your cartridge get selected.if you will not get your cartridges selected.it will everytime show you the option to replace the colour cartridge.
thanks.
Nov 05, 2008 | Lexmark Office Equipment & Supplies
Lexmark X2600 InkJet Printer Logo
269 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
