Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Model U6436 broken shift lever
ModelU6436 broken shift lever How to remove the power assist unit to replace broken shift lever. It is not obvious as to how the unit is removed.
George
    Scholar:
  • 190 Answers
George,
Removal is slow and requires removal of the bottom plate, agitator cavity, the hose connection, and the hood. I can sne a few pictures if you get stumped.
Posted on Oct 03, 2009
How to replace eureka model 4388 belt
Hi, it's Allie from Crucial Vacuum!
Changing the belts in your unit is easier than you think. To do so, you will need a phillips head screwdriver. First, start by unplugging your vacuum as a safety measurement. Using the lever in the bottom of your unit, recline your upright until it lays flat. Unscrew all 4 screws from the floor base cover and remove the cover to expose the roller brush and belts of your unit.
Carefully, remove the roller brush by using your hands, make sure to hold on to the side of the roller brush that has the belt so it does not pop out and hit you. Once the roller brush is removed, gently take the belt off the metal spool, and replace with the new belt.
We have a very helpful tutorial in our webpage that can assist you in replacing the belts on your unit:
https://www.youtube.com/watch?v=IFcjzuplX_o
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-style-u-belt-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 19, 2014 | Eureka Whirlwind 4388 Bagless Upright...
Hoover U5465-900 Power Cord Replacement
hello,
Please checck out the following link for finding the manual of ur device!!...Im sure you can find a manual there!..
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Please post back for how things turned or for further assistance..Thank you!!...
Regards!!!...
Jul 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
The lever came off (drive/neutral)
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My hoover model #u6436-900 brush will not spin. I have changed both belts and still nothing. I even checked to make sure they were the right sizes.
Greetings,
It maybe that the belts were not installed properly, or that the roller brush might be as well. Here's a good video that explains the proper procedure of how to replace the belts on your vacuum cleaner, as well as basic maintenance on your Hoover:
If you find the video helpful, please be sure to rate it by clicking on the thumbs up icon below:
Thanks for watching my video!
Chris
Jan 14, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater brush will not operate
No site available for that, but the height adjustment on this machine only works when you let the handle down.
Nov 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Wind Tunnel U6436-900 power switch is always on. Vacuum will not turn off.
the switch is the problem. if the machine is under it's warrenty take it to your local vac shop if they can do the warrenty. if it's not then you can order the switch and i can walk you through replacing it. you will need to order a switch kit and i beleive the part num. is #40309033 but the num. might have changed
Jul 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-propelled WindTunnel U6436-900 cable
the belt could be broken. check the belt for the drive system.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Brushes won't spin on hoover steam vac
Hello tmc68cam. Most vacuums have a belt driving the rollers/brushes. Unplug unit and remove the housing screws to view internaly. If a broken belt note your model# and search for a local applance repair shop for a replacement. IF not I will need Mgfr.,model & serial# to research to futher assist in the repair. Good Luck.
Oct 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Upright lock broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559827
Generic problem for all Vacuums
Upright lock broken
Posted by diamond8990 on Apr 30, 2008
Upright lock broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and the model # it sounds to me that you have a broken handle release if that is what you are referring to as “Upright Lock Broken” – the handle release lever keeps the hand staying up and in the upright position. So include @ least the brand name and or the model # and I can try to further assist you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
109 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
