Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Flash drive problem
My computer is not reading any flash drive
    Problem Solver:
  • 6 Answers
If you're getting not recognized alert, you need to install Microsoft patch.
take a look at this: http://www.usbman.com/USB%202%20News.htm
Posted on Sep 18, 2009
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope these steps help.
Posted on Sep 09, 2009
Wont read a flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or How to Configure any USB Flash Drive as Storage on Xbox 360
Apr 03, 2014 | Microsoft Xbox 360 Console
Won't read the flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or USB flash drive support for Xbox 360
Printer will read memory card, but i cannot access from pc
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Do not read drive and want to format it
Try inserting it into a different computer.
If you need the data on the flash drive this program may help: -
Nov 12, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I reformat the flash drve and i plug it in my laptop my laptop
Hello, Is it on any computer that your flash drive cannot be read?
Try putting the USB flash drive into a different slot USB on your computer.
There could be a number of reasons for this problem.
Here's a related article that might help: http://ask-leo.com/why_wont_my_system_recognize_my_usb_device.html
Nov 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My computer can't read my flash drive
ok..do the drivers install for the flash drive?? is it recognized by the system?? if yes to all..go to start / computer / right click flash drive in question and click properties....in the tools tab click the "check now" button so it will check drive for errors. that should fix any errors the drive will have.
let me know how your going.
Aug 25, 2009 | Computers & Internet
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
My 2gb kingston usb flash drive cannot open / read to any compute
There are several USB recovery programs available. While I don't endorse any one in particular, I tend to stay away from "free" ones, since I believe in the axiom "there's no such thing as a free lunch" since you don't know what's in it for them.
You could try this company, which advertises a free download (but I suspect they are really a shareware company so it's possible that they will want money for a more expansive version) which may make it possible to fix your drive in one instance at least.
If this data is important to you, it's probably worth spending 30 or 40 dollars to avoid a repeat.in the future, because USB drives get corrupted from time to time.
Anyway, here is the link:
www.premiumdatarecovery.com/
Good Luck and If you find my assistance valuable, please give me a rating.
Jan 22, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Win 98 does not permit flash disk
sir u have to install drivers of flash drive  in win98 (the cd which u got with flash drive )coz xp is plug&play so their is no need to install drivers in xp try it good luck
Oct 22, 2007 | Microsoft Windows 98 for PC
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
54 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
