Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Same problem Replaced the color wheel and still have the same problem, please help!
  • Samsung Master
  • 5,138 Answers
Just exactly is problem? Does TV come on What? Go back to all connections and hook ups make sure everything is connected correctly
Posted on Sep 25, 2009
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
After watching tv for a while I loose the color??
This tv have a colors wheel.The colors wheel effects is dying or dead are make loud squiling noises,motors noises and loose colors and flashes or flashes black&white with the picture.The colors wheel,must be replaced to solved this problems.The colors wheel is pretty hard to replace,because u require take many machanical parts out.Before u can even replaced the colors wheel itself.So hire the tv Tech. to replaced the colors wheel.
Nov 24, 2010 | Samsung DLP HL-P5663W 56" TV
Color wheel sounds like a buzz saw. Fan is quiet because there is no noise in the cool-down mode. Can this be replaced by user?
Baily, I have had my HC1500U color wheel replaced two times due to the color wheel's unpleasant "buzz saw" effect showing up every few thousand hours of usage. It is happening again for the third time and I am still within Coscto's warranty so I am going to have it replaced again...will never buy a DLP projector again...too many moving parts that can break!
Would love to be able to replace it myself if you ever find a place that sells the color wheel.
Feb 09, 2010 | Mitsubishi HC1500 DLP Projector
My samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Jan 04, 2010 | Samsung HLP5085W 50" Rear Projection...
When I turn the tv on It makes an awful high pitched sqeeling sound for about 5 secs then silence then back again. Its a pattern. No Picture and lamp isn't coming on. Im thinking the lamp is trying to come...
Have the color wheel replaced on this unit, The high squeal is the color wheel bearings gone bad. Fortunely on this unit it can be replaced with out purchasing a entire optics engine assembly. The unit will not ignite the lamp until the color wheel has gotten to a pre-determined speed. Around 9600rmp, if it does'nt then the ballast will not get the signal all is well and ignite the lamp.
Nov 07, 2009 | RCA Televison & Video
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Remote stopped working after color wheel replaced
See http://www.consumermeet.com/entry/samsung-remote-wire.html , that seems to address the same problem.
Aug 26, 2008 | Samsung DLP HL-P5663W 56" TV
Wd-52725 mitsubishi please help
Good day, anniedooday;
Your TV's color wheel is bad. Call an authorized service dealer to repair this. It's not an easy job.
Good Luck, big IRISH.
Jul 14, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
