Question about Lexmark X3650 Printer
Printer can't communicate with computer (XP)
Got new Lexmark X3650 Printer it installs the software Disc and after it finishes it says "Print sample page" but when i choose this it says thank you for choosing Lexmark and close.
Then another box appears and says
1----Ensure printer is powered on
2----Disconnect & Reconect the printers power cable
3----Disconnect & Reconect the USB cable
4----Check firewall settings to ensure printers communication is not blocked
5----Ensure the convenience port is not in use
6----Restart your computer
I have done all of the above (except step 4 & 5) as i don't know how
i cant go online with the xp computer as it's not mine and the person that owns it dosent have the internet insatlled. it an Windows XP
My lemark x3650 will not pick up on my computer
If this is your first time using your printer in your computer, then, you need to install the driver enable for it to communicate with your computer. Look for the dvd that came with your printer when it was delivered to you. Insert the disc and let it run. Follow the on-screen instructions.
If you already installed that printer before in that computer but just stopped working, then, you probably have some problems with its communication. The communication between the printer and the computer has been interrupted. I can't tell what made stop working but I can tell you how to make it work fine again.
Here's what you need to do:
Un-install the printer's driver by going to the Control Panel/Remove or Uinstall Programs/Lexmark.... After you uninstall the printer's driver, insert the dvd (printer's driver) in the tray. Let it run. Follow the on-screen instructions.
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 04, 2011 | Lexmark X3650 Printer
Lost installation disc for my lexmark x3650 printer,where can i find the software to download?
Since you don't have the setup disc for this printer you need to download the printer software from this link.
Just click HERE and proceed with the download for your printer.
Oct 10, 2010 | Lexmark X3650 Printer
Printer cannot communicate with printercommunicate
I would suggest:
Go to Printers and Faxes and delete your printer icon
Disconnect your printer's cable (connected to your PC)
Restart your PC
Reconnect the printer's cable
Your PC should see the printer and install the printer's driver software.
Hope this helps.
Sep 08, 2009 | Lexmark X3650 Printer
How to scan photos from a lexmark x3650 to computer
You must install the scanner software that came on your installation disc. If you do not have it you can download it from Lexmark itself. Without the software installed the computer has no idea that your printer has scanning capability.Once you are done you should be pleased, I have always gotten good scans from my Lexmark products.
Aug 10, 2009 | Lexmark X3650 Printer
My printer is new but I didn't get the startup disc so I can"t use my printer . the printer is a lexmark x1270 all in one . the printer turns on but will not print. I have the usb port cable but no start...
If you are using Xp use this link and paste it in the address bar and you will get the file to download.
" http://downloads.lexmark.com/perl/downloads/downloads.cgi# "
And for Vista
"http://downloads.lexmark.com/perl/downloads/downloads.cgi# "
Hope this Help.
Cheers!!!!
Jul 17, 2009 | Lexmark X1270 All-In-One InkJet Printer
Getting precise installation instructions
Log onto the Internet - go to the Lexmark web site, click on "Support" - "Downloads" (or whatever it's called) - then fill in the data for the type of device, the model (ie: Lexmark 3650 printer (or whatever it is) and the operating system you're using (ie: Windows XP-Pro 32 bit). Then download the software to your computer and install it.
NOTE: Printer must be "TURNED ON" when you connect the usb cable, or the software will not find it. If the printer is not plugged in and turned on, the system won't know it's there.
May 25, 2009 | Lexmark X3650 Printer
Cannot Install
go to this page, select your operating system (Win XP or Vista) download and install.
Reminder:
Do not connect your printer to the computer until you are instructed to do so.
this should do it, please leave rating, thank you
May 05, 2009 | Lexmark X3650 Printer
Lexmark x3650 driver problem
try to download windows vistax64 printer driver from their website instead of windows vista only
Jan 13, 2009 | Lexmark X3650 Printer
My lexmark x3650 will not communicate with my computer. help?
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Lexmark X3650 Printer
Lexmark X3650 Printer Logo
533 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
