check power on water valves at the beginig of the cycle,
if it is power you need new water valves
if not you probably need new timer
for parts and more info totalcarefl@yahoo.com
Was this helpful?
Yes
No
Popular Solutions for Magic Chef DU6500 Dishwasher
Have a nine year Whirlpool Gold. The unit will read "2" and after a couple minutes of what...
(More)
Have a nine year Whirlpool Gold. The unit will read "2" and after a couple minutes of what sounds like the pump endeavoring to evacuate water that doesn't appear to exist, the rinse only light illuminates and remains on. If I open the door and close it, the rinse only light comes back on. The "cancel"button removes the 2 and turns it into "--" but when released, the 2 or the rinse only remain on.Tried unplugging and that seemed to help. Have run a couple "normal" cycles but then the same problem resurfaces. The cycle seems to run fine but it ends with the rinse only light remaining on...Read the manual finding no solutions. Filled the tub with water and the water is evacuated quickly, but the light remain on, in one way or another. At times the keys (buttons) are locked and cannot be cancelled. No bad noises when running. What's the remedy? Thanks, Jeff
I have an LG LDF6810ST, when I choose any cycle they all end up display a ''30''. I tried a...
(More)
I have an LG LDF6810ST, when I choose any cycle they all end up display a ''30''. I tried a ''rinse only'' cycle that has only 14 minutes and it still complete count down to 1 thenthe ''30'' will display. Also, there seems to be about 1'' of water at the bottom of the tub. ..PLEASEEEEEEEEEEEEE HELP
Hi, We recently bought a home which has a Magic Chef Dishwasher (tri power sweep wash system). It...
(More)
Hi, We recently bought a home which has a Magic Chef Dishwasher (tri power sweep wash system). It seems to have an endless run time. The wash system seems to last about 90 minutes and over 2.5 hours before the load is finished. This is my first washer so I don't know if this is normal. Thanks a million for your thoughts....
