Question about Garden
Wont start was working two days ago
Troybilt gas edger tb70ss
    Problem Solver:
  • 8 Answers
Look for broken or crackd fuel lines maybe sucking air not gas
Posted on Sep 13, 2009
The string on my Troybilt tb70ss just keeps coming out of the spool when I try to weedeat. I am pretty sure I have followed the directions. What is the problem?
there should be a small hole to put string in on center of spool.
you might be winding the line the wrong way around try winding line in other direction.
Jul 16, 2011 | Troy Bilt Tb70ss Gas Trimmer
How to get the fuel tank off the troy built Tb70ss gas trimmer
Go here and you will see the parts breakdown and diagram for this model...to give you an idea on the parts you will be working on:
http://www.ereplacementparts.com/troybilt-tb70ss-41adt70c711-gas-trimmer-parts-c-26780_27267_27463.html
Aug 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
The spool came unscrewed from the shaft - we can't
It's probably a left-hand thread, turn it counter-clockwise to tighten.
May 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
Describe your troybilt tb70ss pull string Problem.
Do you have mfg instructions? Can be very tricky without following instructions
Sep 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
How do I properly install new line on the tb25sc
if you have the serial number you can get the manual from www.troybilt.com
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybilt cultivator/tiller dies like its out of gas
it sounds like it is going to be your needle valve is stuck and need to be replace,.also your gasket may have a pin hole in it hold up to light to see if there is a hole, if so replace it..
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybilt cultivator/edger starts, but dies under load
yes if it is a 4 cycle
with trimmer LEVEL Take out the plug and the oil level should be at the bottom of the threads where you took the cap off.
sae 30 weight is the oil to use
It can be a problem if you have no oil in the crankcase.
Be sure your stop button is where it belongs and go thru the procedures listed on trimmer to start it
fresh gas and if it is a 4 cycle you need not to mix oil and gas for this trimmer
May 25, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
