Question about Gateway LCD26TV 26 in. Television
I can't programme my Bush LCD26TV016HD television to work with the Sky remote. I have tried codes 1287 0806 1287 1336 1177 0049 & 0157
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
Sky remote code for bush LC-39GL12F
[0157]. Check this code. It is the code for Bush Brand TV with Skyplus.
Nov 26, 2012 | Televison & Video
I want a Sky Plus TV Code for Remote Control of Bush LY24M3 TVDVD Combi please.
hi,
just try the following code one by one.
0157 246, 263, 377, 037, 064, 065, 310, 300,383, 399, 391, 402, 339
ok
Dec 13, 2010 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Sky remote one for all
please follow the steps below:
TV
RED + SELECT
TV
0157
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 05, 2009 | One For All URC-5705 Remote Control
Code for RUC/Sky
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Feb 01, 2009 | Televison & Video
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
Gateway LCD26TV 26 in. Television Logo
87 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
