Question about Cell Phones
Mobile start and shut down
My mobile start and shutdown
  • sakthi ganesh May 11, 2010
    pls check the wether its fully charged or not
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
http://superuser.com/questions/14163/when-windows-xp-wont-restart-how-to-diagnose-how-to-shutdown-without-power-c
May 23, 2014 | Computers & Internet
Samsung galaxy pocket shutdown problem
There are few reasons for a mobile to shut down automatically.
Initially check your mobile's battery is well seated in the device.
This can also happen when some app in your mobile crashes, so find the app you installed before the problem first started and uninstall it.
Still the problem repeats its better you take it to the local Samsung service people.
Thank you
Jan 25, 2014 | Samsung Galaxy Pocket
My HTC T8697 shuts down although is charged up?
it must be virus problem, but surely check that arn't you using an application that is using huge load of memory resulting shutdown of your mobile ? Otherwise try formatting your mobile, or restore phone default settings
Jan 29, 2013 | HTC Cell Phones
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
How do I shut off my computer? L670 series
Normal shutdown: Click on Start button (lower left corner on most PC screens), and then select shutdown.
Abnormal shutdown: If computer is "frozen" and you can't click on Start button, press and hold the power on/off button until the computer shuts down.
Jan 24, 2011 | Toshiba Computers & Internet
All i do is click shut down but it doesnt do anything at all. what should i do?
CTL,ALT.DEL select task manager under there you should see that there is a program that is not shutting down thus causing your issue. You need to shut it down before shutting down the computer again. Otherwise hold down the power button to FORCE SHUTDOWN.
Thanks and do be considerate when leaving feedback and ratings.
May 29, 2010 | Dell Inspiron Mini 10 Notebook
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Dec 12, 2009 | Dell Inspiron 1525 Notebook
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
Nov 17, 2007 | Compaq Presario 5000 PC Desktop
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
