Need help for my Dell Inspiron 9400 Laptop
My Monitor a Dell Inspiron 9400 must be replaced, I was trying to use a Princeton Digital VL1715, but a Message on Monitor says: "Out of Range". Need your help, what can I do? How much would it cost to repair or replace the Dell Monitor? Thanks, Wolf Point Pleasant,NJ
  • 3,940 Answers
Try booting in Safe mode, see if you get video
If you do, reboot in VGA mode, then adjust the refresh rate accordingly
A replacement LCD is about $200 on EBay
Posted on Sep 09, 2009
SOURCE:
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 laptop display problem
First power the system on using Fn+Power and see if the diags run and you have video. If you have video in the diagnostics, then I'd suspect the video card as the failure point.
Also connect an external monitor and press Fn + F8 to activate the VGA port If you get video on an external monitor, I'd suspect the LCD as the failure point.
Dec 26, 2009 | Dell Inspiron 9400 Notebook
I have no sound through my headphones - Dell 9400
Greetings of the day ..
Try another headphones if possible..you have already checked the speaker so half of thework you hve already done .. try to get a diffrent headphones from friends if they work .. then its your headphone gone bad & you would need to replace it.
If you still get this issue .. please write to me .. we will work together on this issue..
Take care.
Dec 19, 2009 | Dell Inspiron 9400 Notebook
Princeton VL1715-1 trying to identify the two capacitors C914 & C915 to replace them. Can you hlep?
I can give you the way to decipher the capacitor manufacturer codes, on the side of the capacitor.
This way you can find out what Voltage they are, and what Microfarad's.
1.Japanese and Taiwanese Electrolytic Capacitors,
http://www.hardwaresecrets.com/article/595
(Reading all 4 pages of the article is relevant to identifying)
Sep 04, 2009 | Princeton Digital VL17151 17" Flat Panel...
Try and determine what is wrong with your LCD screen first and you can then decide the best course of action. Follow these instructions to determine the fault and then check out LCD Parts WEB site for parts, replacement LCDs, service and DIY info..
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
Princeton VL1715 monitor's pwr button is "locked." Can't turn-off
I have resolved this situation on other brands by holding down one of the advustment buttons while holding the power button in. You will see a message about "unlocking button" and a sliding bar if you find the right buttons.
Monitor Mike
Jan 06, 2009 | Princeton Digital VL17151 17" Flat Panel...
Princeton VL1715-1 no display
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Dec 22, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
Computers & Internet Logo
66 people viewed this question
Alun Cox
