Question about Vestax Vci 100 Midi Controller
I have traktor pro and the midi mapping files im downloading are not working
  • hgroup504
    hgroup504 Sep 09, 2009
    do you have midimapping files for the vci 100 traktor pro?
  • hgroup504
    man i dont like this ! i mean if i wanted to get a you tube answer i think i could manage that on my own and not for $10. Are you serious?
  • 10,515 Answers
The first step towards fixing this would be Firmware Upgrade.
Go for firm upgrade, if possible and let me know the status if that could fix the issue or not.
Thanks.
Posted on Sep 09, 2009
    President:
  • 2,777 Answers
Check these out, midi mapping is extremely complex with this software. These videos are definitely the best way to learn midi mapping:
Let me know if you are still unable to get the midi mapping going.
Thanks
Tim
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
Vestax typhoon controller jog wheel stays red
look at the back of your deck there shold be two little nobs that say touch sensor level turn it down to min or at least dont have them all the way up
Jun 11, 2012 | Vestax Typhoon USB DJ MIDI Controller with...
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
May 29, 2011 | Casio Ctk491 Midi Keyboard
I just bought the Vestax typhoon but everytime I go to the setup wizard in Traktor it says controller not connected and I'm not able to use the controller
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
Jan 04, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Feb 22, 2010 | Vestax Vci 100 Midi Controller
Vestax Vci 100 Midi Controller Logo
169 people viewed this question
Top Vestax Music Experts
Michial Gueffroy
Jeff Turcotte
Jeff Turcotte
Are you a Vestax Music Expert? Answer questions, earn points and help others
