Question about ActivCard Gold 2.2 for CAC (gacg22cl)
Activcard gold 2.2 error
I have Activcard gold 2.2 with SP2 and I am receiving this error on several computers on my LAN; unable to load card dependant library! with several devices (keyboard and card reader) and with several smart cards issued at different periods.
2 Suggested Answers
  • 241 Answers
SOURCE: i need to know how to install the software for my
If you are running XP or Vista, just plug the reader into the USB slot and the system will automatically load a driver. If it doesn't, put the CD that came with the reader in the CD drive and run the exe file and follow instructions. You may have to install the software first or plug in the reader first. Manufacturers vary on the order of install.
Posted on Sep 16, 2009
FROM WHERE CAN I DOWNLOAD WINDOWS XP SP2 LAN DRIVER FOR HP PROLIANT ML110 G6
Hi ppswalia
Since this is a Server, rather than an ordinary Desktop computer, it is not designed to work with normal Windows XP Operating Systems. It is designed to work specifically with Windows, Unix and Linux Server Applications. See here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
There are 2 things you can try.
You can try installing the LAN/Ethernet Drivers for the various Windows Server versions from the above official HP Downloads and Drivers Support Website and see if one of them just happens to coincidentally be compatible with XP SP2.
Assuming there are no further compatibility issues between other Server Motherboard Devices and Win XP SP2 Drivers, you could open the Server case and either bypass any on-board LAN/Ethernet/NIC Port or remove any separate LAN/Ethernet/Network Card installed and install, instead, a pre-confirmed Win XP compatible LAN/Ethernet/NIC Card and then install the drivers for the new card.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 18, 2011 | HP ProLiant ML110 Server
My FSX has been running flawlessly for 2 year now it freezes a few minutes into flight Sp1 and SP2 have been installed and I reinstalled FSX and have the same results HELP!!!! Please I also down loaded...
My best suggestion here is making sure that your graphics are up to date. Whether you have on board graphics or a graphics card, check the drivers and update if necessary. If that doesn't fix the problem, are you using the gold edition, or just flight simulator x? The gold edition contains the Acceleration expansion, and does not recommend installing SP1 or SP2 as it is already updated through the Acceleration Expansion!
Aug 12, 2010 | Microsoft Flight Simulator X
Cac is readable by reader but is not permitting its use
ActiveCard Gold had known problems that were never fixed. Upgrade to the newer Active client 6.2 very reliable and stable CAC program. Also has several very useful tools in it as well. DoD switched to this a few years ago and has worked very well.
May 21, 2010 | ActivCard Gold 2.2 for CAC (gacg22cl)
CF19 LAN connection problem
Hello there, have you check your LAN IP?Make sure that your LAN IP is uniqe from other pc on your LAN otherwise your connection will be limited.
Mar 28, 2010 | Panasonic Toughbook 19 Laptop Convertible...
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
Need software for Vista
Hi Jim,
You may find few software for Windows Vista;
http://www.bestvistadownloads.com/
For rest, let me know.
Warm regards,
Anirban Mazumdar
Oct 08, 2009 | ActivCard Gold 2.2 for CAC (gacg22cl)
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Cant find the download
you may find the software in the following link-
http://www.activcard.com/smartvpn/index-us.html
Dec 06, 2008 | ActivCard Gold 2.2 for CAC (gacg22cl)
Error on startup - agquickp.exe can't locate acdbilog.dll
Check whether it is something else other than the pogram like virus or spyware by checking with this info.
The process ActivCard Gold Quick Fill belongs to the software ActivCard Gold by ActivCard Corp or ActivCard S.A.
Description: agquickp.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows XP are 208896 bytes (66% of all occurrence), 131072 bytes.
There is an icon for this program on the taskbar next to the clock. The program has a visible window. Program can be uninstalled in the Control Panel. File agquickp.exe is not a Windows system file. agquickp.exe is able to record inputs. Therefore the technical security rating is 2% dangerous.
External information from Paul Collins:
"QuickPassword" can run at start up. Smart card-based authentication and digital signature client software
Important: Some malware camouflage themselves as agquickp.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the agquickp.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security.
And you check about numerous startup files here :
http://downloads.subratam.org/startuplist.html
Uninstall ompletely.
Run a virus scan and search whether there are any thing found.
Delete the threats found.
And use the application from the known secured source only.
Then install the software.
You will not be getting any errors.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | ActivCard Gold 2.2 for CAC (gacg22cl)
Computers & Internet Logo
175 people viewed this question
Top ActivCard Computers & Internet Experts
David Payne
David Payne
Are you an ActivCard Computer and Internet Expert? Answer questions, earn points and help others
