Question about Kitchen Ranges
Bosch Gas Range S/I,30,dual,S/C,conv,WD,Probe,all steel No. HD17282C
The new stove has just been installed and the oven fan noise is unbearably loud. The fan runs constantly during the bake mode. Is this likely a fan problem or is the fan noise a feature of this model?
My e-mail address is meljohnsonon@yahoo.ca
Thank you for your help.
Mel Johnson
SOURCE: Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
Posted on Sep 23, 2008
  • 15 Answers
SOURCE: GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
  • 1266 Answers
SOURCE: can't get oven to heat over 175
not very specific in your statement, so I'll venture a few things to look at.
Check to see that it is getting the correct power (voltage). Could be wired wrong.
Several things could be causing this. If electric, wrong or low voltage. If it is new, just out of the box, then it could have received some shipping damage. Delivery trucks never hit potholes (Ha Ha). A simple wire could be loose or probe knocked out of position.
Something is telling the controls that the desired temp is reached and the unit it cycling off.
This may or may not be a simple fix.
Posted on Feb 13, 2009
SOURCE: KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Posted on Jul 04, 2009
We have lost our manual and I can't seem to reset the clock
model C970502321 lights all come on but oven and burners do not get hot
Mar 25, 2010 | Bosch HDI7152 Stainless Steel Dual Fuel...
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Stove not working
a bit more info please, electric or gas, fanned or coventional.
Apr 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Kitchen Ranges Logo
412 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
