Question about Refrigerators
Hi, I have a defrost problem on my fridge/freezer, ie, the heating element doesn't seem to come on and so over a period of 2 weeks the coils clog up and the temperatures raise. My question is, is the defrost timer intergrated into the pcb on the back lower corner and will i need to replace it. thanks tim model s20d rbb32 and i think the board is 481221778178
  • 1 more comment
  • timothyelee Sep 09, 2009
    hi thanks for your reply, it's a whirlpool and yes checked the element for continuity not sure where the metal thrmostat is?
    thanks for the reply, it's a whirlpool s20d rbb32.
    i checked the heater for continuity and the thermister was mounted ok but I havn't checked it's working properly.
    Definately need to before getting a board
  • Dan Webster
    Dan Webster May 11, 2010
    Check the heater for continuity, if it is good then check the defrost terminator Both of these are pretty much standard but the terminator will have to be at least 25f to close so checking it warm does no good. These newer ice boxes have a thermister mounted on the coils to determine if defrost is needed. The board measures how many times the door has opened and closed and how many times the compressor shuts on and of AND the drop in resistance to the thermister. If all agree the board starts a defrost cycle. Lots of folk buy a new computer board only to find out a crappy cheap thermister is the probo. Make sure the thermister is properly seated in place and reading the correct ohms before blowing any money on non refundable parts. If I had a model number I might have a manual available.
  • 39 Answers
Did you check your defrost heater and defrost bi-metal thermostat? what brand your fridge..i can't find out by model#, totalcarefl@yahoo.com
Posted on Sep 09, 2009
  • 80 Answers
I would begin with the wiring diagram...you will have a better understanding with it...next with everything in place i would bypass the board by jumping line to heater (at the board it was j11 and j8 on mine).. if still no heat....then i would check the heaters resistance (ohms).....if that checked ok i would replace the defrost thermostat which would be in series with the heater...
Posted on Oct 02, 2009
  • Refrigerators Master
  • 8,220 Answers
Want to search for another model? New search We're sorry. No exact or partial matches were found. Verify your model number and try again. Don't know it? We can help you below.
No matches were found. TIP: Check the model number plate again and make sure you enter all numbers and letters.
Get help with your model number.
Did you mean to do a part number search? Search by part # Need help locating the model number on your product? Product category Select a product category Cooktops Cooking Hoods Microwaves Ranges and Ovens Dishwasher Washers & Dryers Refrigerators & Wine Coolers Freezers Trash Compactors Appliances-Small Automotive Computers/Office Equipment Floor care Hardware/Tools/Painting Heating/Cooling/Ventilation/Conditioning Home Electronics Home Improvement Products Plumbing/Water Treatment Chainsaw Lawn Mower (Walk behind) Snowthrower Tractor Other Yard and Farm See All Categories Search Still can't find your model number? We can help. Email us or call (800) 252-1698
GE fridge not cold.
If the coil (in the freezer) is icing up then it's not being properly defrosted on a regular basis, ie. 2 - 3 times a day. On older models it's usually just a simple matter of replacing the defrost timer. On newer models, the defrost timer is integral with the 'motherboard', so the whole (expensive Chinese made) motherboard must be replaced because they're not serviceable.
Less likely (but possible) are the defrost heating element and/or temperature sending unit found on or near the coil itself. Least likely is a low refrigerant level, which would indicate a leak.
Mar 27, 2014 | GE Refrigerators
Maytag MSD2651KES the coils are iced over, both the freezer and the fridge are no longer cold. This is the third time in 3 years this has happened, having to replace the Defrost Thermostat and the Defrost...
It could be a faulty defrost heating element or a bad terminal connection somewhere in the defrost wiring circuit. Make sure the doors seal properly. ie. no gaps between the door seals and the unit when the doors are closed. Door seal leaks can cause coil icing. If okay, the heating element is not working properly (heating up) during the defrost cycle. ie. The ice on the coils never melts off the evaporator coils.
Aug 12, 2013 | Maytag Refrigerators
Hi, I have a Fisher and Paykel E402B Fridge/Freezer. It has not been working properly for a couple of months.. It does not cool/freeze properly. Through investigation I discovered that the coils and fan...
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Jun 21, 2011 | Fisher and Paykel Refrigerators
Fan runs, but does not cool?
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it?ll go into defrost, but it will either tell the timer that it?s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element). defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 11, 2009 | Magic Chef Refrigerators
Cleaned the coils but freezer not freezing and inside not getting cold what is wrong
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Samsung side by side fridge is not cooling properly. The freezer is fine but the refrigerator does not cool enough. I cleaned it recentley but just wiped it down - nothing odd
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 11, 2009 | Refrigerators
The freezer is freezing to the extreme fridge not cooling at all
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model also check the termination switch inline with the elements
Aug 09, 2009 | Refrigerators
Coils inside freezer keep icing up.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Fridge slowly gets warmer and stops working
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Jan 11, 2009 | GE Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
233 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
