Question about Acer Aspire 4530-5889 Notebook PC
Blue screen appear when formatting...and this number appear: stop:oxoooooo7B(oxF78D2524, oxoooooo34, oxoooooooo, oxoooooooo
  • owaiss Sep 10, 2009
    just add the ram....before: 1G and i add 2G ...so now can read both...but still same problem
  • Laxman Bisht
    Laxman Bisht May 11, 2010
    Please inform if you have made any hardware changes. Check if you are able to boot the computer in safe mode.
    President:
  • 1,996 Answers
That stop code refers to an inaccessible boot device. (0x00000007B) See the list here. and the MSDN article here. There are a series of MS KB articles to choose from that may help you to resolve the problem...
See here for some possible solutions...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 09, 2009
    President:
  • 1,653 Answers
Have you added any hardware since it last worked OK such as RAM or changed the HD? If so take it out and try again. Have you changed any BIOS settings? If so set them back to how they were and try again?
Did the system crash and you are trying to reformat it? If so you may have an HD or HD Controller problem.
Does your system boot from the Op Sys CD / DVD? If so leave it doing nothing for up to 60 mins to make sure the system is not overheating. If it crashes while you are doing nothing then it could be any number of problems but most likely are RAM problems, CPU problems and HD problems. You could try downloading a copy of PCHealth or SiSoft Sandra to try out and diagnose the system to see if it reports any issues.
Failing all that then take it to a repoair shop for an estimate!
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
Windows vista on my laptop did not boot that happend when i was made some windows updates so i try to set up another windows xp from a new bootable cd ,the windows begain to set up but its shut down and a...
I had a similar problem but I can't recall if it was the same error number as in your message---what I did was used the recovery console and re-wrote my master boot record (MBR) my error was in the MBR causing my computer not to boot up in the first place. Your bootable cd should give you an option to use the recovery console before you reinstall, take it and use "fixmbr" at your dos prompt. XP works like that, but I've never had that problem with vista yet....it's worth a try if vista does the same.
Feb 14, 2011 | Computers & Internet
My acer aspire screen says technical info ***stop oxoooocif5 (oxoooooooo,oxoooooooo,oxoooooooo,oxoooooooo) can not get any joy for getting into windows,anyone got any ideas to fix this.
And blue screen come on with white letters. It can caused by viruses, from unexpected shut downs and a lot of such kind of things, most of those cases operation system is demaged and may fix by reinstalling it, it you are familiar to bootable medias an a lot of tools you can scan your PC with sacndisc/chkdisk and problem may automatically disappear. Use F8 at startup and choose SAFE MODE to ensure that OP system is not "almost dead". Download any linux LIVE immage and boot from it, if PC is working LINUX wil turn on and no warnings will appear.
Jan 04, 2010 | Computers & Internet
***STOP OXOOOOCIFS(OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO)ON A BLUE SCREEN,CAN I CURE THIS?
The first step is to determine whether your computer is getting a blue screen because of an internal program problem or a hardware malfunction. 80% of the time, blue screens are caused by internal issues,
The most common symptoms or signs of a hardware issue is a pattern of consistent behavior leading up to the blue screen crash. In the case of an over heating problem, you likely would notice that your fan in your computer was running more often - or not at all. This would likely also come with an increasingly repetitive crash cycle. For example, your system shuts down 10 minutes after you turn it on regardless of what you are doing. Also, if you have recently installed something new on your system like more memory or a new hard drive / web cam or other actual physical device, try taking it out and see if that fixes the problem.
Dec 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have a aspire 6930 laptop from acer it will boot past post but not into windows not even in safe mode it just goes to green bar like windows is starting then blue screen with error stop:oxoooooo7b...
id reinstall vista ! if you want to do this you need to get in to the bios which u press F2 i believe when the comp first starts up when your in the bios scroll along to boot menu u shud see a boot list with your hard drive at the top ,you need to change your dvd drive to the top so itll boot from dvd , restart your computer with a windows vista disc in the dvd drive and i think it shud give you an option to fix your system if doesnt work then definitly do a clean install of vista using your product code . hope this works
Oct 18, 2009 | Acer Aspire 6930-6082 Notebook PC
My laptop is driving me nuts it will boost thru post but when it starts green bar in windows vista a blue screen flashes up with this code stop:oxoooooo7b (ox8o2o3bao,oxcooooo34,oxoooooooo,oxoooooooo)...
I got you man.. follow these directions and you should be good to go..
you need to run a nifty little program called Spinrite on your laptop. You can download it via BitTorrent2.gif HERE
you will need to use a program to burn the ISO image2.gif onto disk and make it bootable. I use PowerISO . It is very easy and straight forward. You can download it HERE (use the name: Dr.Upload
serial: SKSIP-7AIX1-8YWEZ-U197K-T88IE ) to remove restrictions.
Open the iso file2.gif using PowerISO. Now we have to make it a bootable disk image2.gif. Spinrite comes with FREEDOS instaled, but most laptops don't like using it.
Follow directions here on making a bootable image.
after burning your disk boot your system up with the cd. when you get to a prompt , ie C:\\ you will need to change it to your default cd drive mine is E:
after changing the drive letter type SPINRITE
the program will start - follow onscreen directions and change scan level to 5. after program finishes reboot after removing disk.
should start up and run like a new machine.
Oct 17, 2009 | Acer Aspire 6930-6082 Notebook PC
Operating System
Before you could start the installation remove all the external devices connected to the laptop only ac adapter should be connected the restart the system and hit F10 several times till you see a diffrent screen the BIOS and hit F9 to reset to default and then press yes and then press F9 to save and exit and try to run the installation..
Aug 31, 2009 | Computers & Internet
I have HP Pavilion dv5-1110ee with Windows Vist but i want to install Windows XP. When i install XP then problem comes out (stop: oxoooooo7B oxF78E0524 oxCooooo34 oxoooooooo oxoooooooo) what i do, please...
It is becasue of harddisk bed indexing.
For that first boot your computer with winxp then enter in recovery console mode then type in prompt "chkdsk /r'
then press "y"
then it fix errror on disk.
Then dlelete all partition and format 1 partition then install winxp.
Aug 23, 2009 | Computers & Internet
For some reason my personal computer at home stopped running windows vista and asks if I want to start the operating system in safe mode or normal mode.  When either option is chosen I get a blue screen...
Everything I have researched states that your problem is with the installation of SP1 for Vista. Unfortunately the remedy is a reinstall of the operating system.
Dec 30, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Acer Aspire 4530-5889 Notebook PC Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
