Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Need wiring diagram to wire pressure switch to magetic starter.
I have 80 gal.5hp motor with 5hp pump.
need wiring diagram to connect pressure switch to the magnetic starter.
THANKS RICHARD
  • 65 Answers
SOURCE: the pump builds up pressuer to 80 to100 psithe
hi your problem sounds like the non return valve is either missing or is passing back pressure
the nrv should be on the hose that supplies the tank
Posted on Mar 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
  • 497 Answers
SOURCE: I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Posted on Oct 26, 2009
  • 99 Answers
SOURCE: trying to rewire my ingersoll
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Posted on Feb 19, 2011
SOURCE: Need wiring diagram to wire
3 phase 7.5hp magnetic start wire schematic
Posted on Dec 06, 2011
Need help wiring a 5HP 1Phase motor on Powermatic 66
As you only have 4 wires from the motor it should be straight forward as two would be from the start winding (Black and red) and the other the run winding (White with yellow stripe and Blue). You should be able to check this with a tester as there should only be continuity between the wires as mentioned above.
Reference the thermal switch, I am not 100% sure on the color codes but have attached a diagram which should help but will advise as best as I can on the connection. The diagram is for a high/low voltage but you can disregard the winding on 3 and 4 but should help on the understanding.
Join the blue and black wire from the motor together and connect to the black wire from the supply. You should be able to run the motor (Excluding the thermal switch) by connecting the White with yellow stripe and the red wire together along with the white from the supply. To include this switch I would presume that you would connect the red wire from the motor to the brown wire from the thermal switch, the yellow wire from thermal switch to the White with yellow stripe from the motor and finally the white wire from the thermal switch to the white from the supply.
Jan 29, 2014 | Powermatic Saws
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
How do I wire my 60 gal 3 hp IR commpressor? What size wire, what size breakers, and where on the motor do I attach my wires. Motor says 15 amp, 220 volt. Thanks, Clint
I would use a # 10 wire size with a 30 amp breaker. The motor should already wired to the pressure switch unless it has a mag starter. If no mag starter incoming power should go to pressure switch not motor. If unit has a mag starter incoming power should go to top of mag starter.
Jan 12, 2011 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
How do i connect he differenial pressure switch into the 3ph star/delta starter circuit?
Your question is a bit unclear, but I assume you are asking how to wire the pressure switch in a piston compressor.
See the diagram, below.
You should have a wire from the L1 (first incoming main voltage) terminal to the pressure switch, and from the other pressure switch terminal back to the starter coil. You will also have a wire from L2 (second main voltage terminal) to the overload, and from the other overload terminal to the other side of the coil. In this arrangement, the motor starter coil must be rated at the SAME VOLTAGE as your incoming power.
This diagram works the same for single phase machines (they just don't have the third wire coming from the supply through the starter and overload to the motor.
If your machine has other safety controls (like a low oil switch), It can be wired in series with either the pressure switch or the overload.
Nov 03, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
How do i connect the differential switch into the 3ph star/delta starter circuit?
Nov 03, 2009 | Ingersoll Rand Ingersoll-Rand Air...
I have a Coalman Powermate 6.5 Hp 60 gal. compressor model C650C600VIB103. I want to know to connect the elect. cord correctly.
Does the unit have a starter or just a pressure switch , if just a pressure switch it should be marked with line and motor , the wires on the motor should go to the motor terminal and the line terminals are the power supply , if the unit is 110 volts make sure you put the wires on by color , the white wire goes to the motors white wire and the black to the motors black wire , if this is 220 volts it does not matter which wire connects just put the two black wires on the line terminals. One wire per terminals please.
Jul 17, 2009 | Coleman Powermate 60 Gallon Air Compressor
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
1,114 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
