Question about Lexmark E323 Laser Printer
How to remove the fuser on a lexmark E 323 printer
How do i reset fuser count on lexmark c792de
lexmark 792 printer are reset based on a chip in the fuser. The fuser must be replaced. Make sure you completely power off the printer before you remove and replace the fuser.
Sep 10, 2014 | Lexmark C792DTE Laser Printer
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Lexmark E460dn paper stuck
If the paper is stuck on the fuse, I am assuming you mean the fuser. You will probably have to replace the fuser. You can remove the fuser and try to remove the paper and then reinstall the fuser. Could be a sticky sensor as well.
Apr 12, 2014 | Lexmark E460dn Laser Printer
Lexmark fuser removal
For fuser removal, It is recommended that you contact Lexmark Technical Support or your nearest authorized service provider.
May 07, 2012 | Lexmark E450dn Laser Printer
The paper is jamed in the back and I can't find a way to release it. Lexmark E340
jammed in fuser which is in the back to get to fuser remove rear door remove redrive two screws you will see the fuse be carful output sensor in middle of fuser just pull it gently if it jams again may need a new fuser
Sep 08, 2011 | Lexmark E340 Laser Printer
My printer will not print and is reading SVC H2 ERROR. How do I resolve this?
According to the Lexmark Manual, SVC H2 ERROR is a fuser temperature error. The Fusing temperature is not reached within the warming-up time period.
Try to remove and re-install the fuser. If the problem still occurs you will need to replace the fuser assembley.
You can find the lexmark manual here for more information
ftp://nice.ics.perm.ru/pub/drivers/printer/Lexmark/CD%20new/%D0%94%D0%B8%D1%81%D0%BA%202007%20%D0%B3%D0%BE%D0%B4/Lexmark%20C500n/b.%20C500n%20Job%20Aids/C500n-5023%20Service%20Manual.pdf.
May 27, 2011 | Lexmark C500n Laser Printer
Lexmark printer C780 receiving 202.30 error code, cannot figure out what to do to fix it.
This error indicates a jam in the fuser, you need to remove the fuser and make sure that all the flags are intact and move properly. Pull the fuser out, remove the oil housing and then tilt up the paper guide, make sure that the exit flags are moving smoothly. Reintall fuser and turn printer back on.
May 13, 2011 | Lexmark C780dn Printer
Lexmark C534 . Problem is 920.08 is this the
Here are some steps you can follow to remedy the problem:
1. Turn the printer off, and remove the rear cover. Check the connector JFUSER1 for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage. Is the cable damaged? If yes, replace the fuser cable. If not,
2. Remove the fuser. Check the DC autoconnects on both the fuser and the printer for damage. Are the connectors damaged? If yes, replace the JFUSER1 cable. If not,
3. Check for the following continuity between the DC autoconnect and FUSER1. Is the continuity present? If yes, go to step 4. If not, replace the DC fuser cable.
4. Replace the fuser. Does the error clear? If yes, problem solved. If not, replace the system card.
Apr 05, 2010 | Lexmark C534N Printer
Lexmark C534DN. Getting eror 120-10. How to repair?
This message indicates that an error has occurred in the fuser. Turn the printer off. Remove and reseat the fuser. Turn the printer on again.
If the error continues remove the fuser again and check to see that the cam shaft follower ( on the right side) is properly in the groove. If it is above the cresent shaped groove, press it down into the groove.
If it is correcly in the groove, then the fuser will need to be replaced.
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Lvps
Remove the fuser assembly
Remove the rear cover
Remove the fuser top duct screw and disconnect tab
Remove the top duct
Remove the redrive belt cover duct
Remove fuser left duct
Remove fuser bottom duct
Swing lever and disengage VTB shaft
Remove the fuser drive assembly screws and remove the fuser drive assembly
Disconnect the J33 and J35 cables from the system board
Remove the four LVPS screws from the rear of the printer
Remove the right rear cover screw
Remove the screw from the top of the LVPS and remove the LVPS from the
printer.
Installation notes
When installing the new power supply, set the voltage range switch to the proper power setting for the
geographic area you are in.
Be sure to set the voltage range selector switch (A) on the LVPS to the proper setting.
Aug 25, 2008 | Lexmark C760 Laser Printer
Lexmark E323 Laser Printer Logo
217 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
