Question about Zenith R57W46 57" Rear Projection Television
My Zenith Projection HD TV is displaying a series red lines
My Zenith Projection HD TV is displaying a series of red laser like lines across the TV screen causing blurry images and duplicate words in an arc like fashion
    Problem Solver:
  • 12 Answers
It probably needs the convergence circuit repaired by a qualified technician.
Posted on Sep 09, 2009
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
My zenith tv is showing 2 or 3 colors lines on bottom left across tv
you need to replace the convergence amplifiers if you know how to solder or replace the complete convergence board a lot easier to do judt plug and play
Aug 20, 2009 | Zenith R57W46 57" Rear Projection...
Not display hd channels thru cable box
cable conections between cable box and tv have to be done across component input (three RCA conectors BLUE GREEN RED for video and white + red for audio)
Apr 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Zenith D52WLCD red line across the top of picture
If you see a redish bar across the top, you have a bad light engine. You may also see a bluish bar across the bottom. Contact local service company for repair.
Nov 24, 2008 | Zenith D52WLCD 52" Rear Projection...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Red light
Here is a "dime"==STK392-110 IC's need to be replaced.Then convergence in servicer mode will make all the lines straight. NOTE:Please give your tv model # next time!
Oct 02, 2007 | Philips 9P5544C 55" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
210 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
