E2 alarm continues even tho everything is set up properly. Paper will not feed. printer is brand new. never used for the purpose it was intended because the E2 alarm continues to come on.
Do not know what E2 alarm light means
Error Code for Canon MP160 E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error VOTE ME IF THIS SOLUTION IS OK
Aug 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam......removed paper but now printer continues to only partially feed..paper stops after coming out of the paper tray and feeding up...
It is a possible roller mechanism issue. You can try to clean the rollers tho and check. You may have to open the back of the printer to reveal the rollers. Also try to use a different type of paper.
Feb 13, 2011 | Canon imageCLASS® MF6550 Laser Printer
Error message E 2 's flashing .. what should i do?
If the alarm light is solid amber E2 indicates a paper feed error.
This can usually be cleared easily.
If the Power light and Alarm light are flashing green and amber then the E2 indicates an error requiring Canon servicing might have incurred.. If after disconnection it reappears then it looks like a bin job as nobody on the internet appears to have any solution for this one and anything involving Canon would be as much as a new printer.
Jan 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi i have a canon MP210 and it is showing E2 and the alarm lamp is flashing. there is ink and paper in it any suggestions??? I can't find the user manual!!
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Nov 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
I had a paper jam and got the paper out but still shows E2
E24 = Purge unit error (bagian cleaning head)
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Brand new printer. Jams about 80% of the time
please you chack paper prassor adjustment undr paper tray
Jul 14, 2009 | HP PhotoSmart 7260 InkJet Printer
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
74 people viewed this question
jasbo
jasbo
