Question about Acer AL1912B 19" LCD Monitor
My monitor turns itself off when it wants and also turns on when it is not on any ideas
    Scholar:
  • 53 Answers
First, check all electrolytic capacitors and replace those which are blown or rounded. Next, if when it shuts down the green LED also turns off, then
on the controller PCB there's tiny transistor-like chip U406. Remove it from the board and try to turn the monitor on. That's reset circuit, you could live without it.
Posted on Sep 10, 2009
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
Oct 14, 2011 | LG W2234S 22" LCD Monitor
When I turn on the monitor, it turns off itself ba...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My monitor went black this morning so i rebooted my system. didn't work. i then turned it off and it will not turn back on.any ideas
check screen light is it light green/yellow or is it orange in colour.....if it is orange check PC is turned light green also....if not then it defined that their is a problem with your PC itself and not the screen......have a technician looked @ your PC.....
Nov 05, 2009 | HP Vs17 17" LCD Flat Panel Monitor
My monitor turns itself on and off with no prompting
Go into the control panel and check the system settings. You might have it set to turn the monitor off after a low number of seconds of use. If you have it set for 30 seconds, if you don't use the keyboard or mouse for 30 seconds, the monitor will shut off. When you start to use it again, it will come back on.
Feb 10, 2009 | IBM POWER SUPPLY 120W 25P4966 Power Supply
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
HP TCO '03 MONITOR SHUTTING OFF
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
May 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor Settings Adjust Itself
try connecting some other monitor to the system, if u do not face the issue, then issue is with the monitor, some hardware fault.
Feb 14, 2007 | AOC LM-727 17" LCD Monitor
Acer AL1912B 19" LCD Monitor Logo
577 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
