DISPLAY BUTTOM FLASHED 5 TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL# 9726928
    Problem Solver:
  • 12 Answers
The TV is in protection shutdown mode. Something inside the set has failed and should be looked at by a qualified technician.
Posted on Sep 09, 2009
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
No sound, no picture standby light blinks 5 times, pauses, blinks 5 times, etc. This is a Sony Trinitron 36" Wega tv about 7 years old.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Nov 12, 2010 | Televison & Video
NO PICTURE/RED LIGHT KEEPS FLASHING/SOMETIMES PICTURE COMES ON AFTER NOT PLUGGED IN TO POWER
My KV34HS510 Led flashed 4 times then stops for a few seconds and repeats. Is this the D Board MCZ3001D IC problem?
Feb 02, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
DISPLAY BUTTOM FLASHED 5 TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL#...
Hi
Thanks for using FixYa. You need to check the horizontal and vertical output wave form at the high side of the deflection which should be a normal horizontal/vertical pulse respectively. Now check the HV output transistor on all three elements and also check the regulator transistor which might have short. Replace the parts/diodes which are gone bad and can be easily replaced. You can order these from the following link --
Projection TV spares parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | Televison & Video
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Dead Phillips 36PT842H
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jun 03, 2017 | Philips 36PT842H 36" TV
Tv blinks on and off ever 5-10 seconds and display will not turn off
sounds like the sets motor boating from the power supply like a bad regulator IC or a bad capacitor.
Aug 16, 2006 | Sony KV-36FS16 36" TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
