Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Same Printer, same problem
How is it that this printer would stop working simply by upgrading to Snow Leopard? That's insane! I use a Mac, no a WIndows PC!!!
My new operating system doesn't recognize my scanner any longer but does do fine with the printer which are both the same machine. How do I fix that? I moved from Mac OX leopard to Mac OX snow leopard....
Shortly after the world started upgrading to Snow Leopard, reports began emerging that many Hewlett-Packard printers were incompatible with the upgrade. So, you can wait till you get the updated driver which is compatible with Mac Snow leopard.
Good Luck!
Aug 23, 2010 | HP Photosmart C7280 Laser Printer
Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
Jul 22, 2010 | Olympus P-440 Thermal Photo Printer
No printer driver for HP LaserJet 4ML on Mac running Snow Leopard
The drivers should be packaged into snow leopard. This printer is listed as a supported printer for Snow Leopard.
this link will walk you through the process
Hp.com
Al
Eliteprintersolutions@gmail.com
Jul 10, 2010 | HP LaserJet 4ML Printer
Lexmark X2650 scanner in Mac OSX 10.6.2 (Snow Leopard)
You need to update your driver by getting the latest software in the Lexmark website here. During software update what usually gets updated are the basic functionalities. In this case it looks like the scanner is not being updated as well. Hope this helps.
Mar 16, 2010 | Lexmark X2650 All-In-One InkJet Printer
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Mac upgrade means Xerox printer won't print!
There are apparently incompatibilities between some Xerox drivers and the security-improved Snow Leopard. It seems that many pieces of software (and drivers) relied on not-so-clean techniques to cut corners while operating. These techniques are no longer allowed by Snow Leopard (the same problem afflicts XP SP3, Vista and Seven).
This article lists several problems, explanation and (perhaps) fixes:
http://www.ucalgary.ca/it/news/4366
Meanwhile, Apple is working to some workarounds too (there is an update linked in the article which may be of interest to you).
Nov 08, 2009 | Xerox Phaser 6115MFP/D Laser Printer
I have upgrades to Snow Leopard on my iMac and cannot access the printer commands to cheque the printer heads, and ink levels.
You can find useful information on site? http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp Mac OS X Snow Leopard Support Contact Support rightmenudottedline.gif snow_leopard_logo_sm2.jpg Welcome to Mac OS X Snow Leopard v10.6 support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Mac OS X Snow Leopard v10.6.
Check your Epson product CD to see if it already contains Macintosh OS X 10.6 drivers. If the CD indicates support for Macintosh OS X 10.6, follow the instructions that came with your Epson product to install your drivers and other software.
If your Epson CD does not indicate support for OS X 10.6, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR SNOW LEOPARD COMPUTER. Follow the step-by-step instructions below to obtain the latest software and utilities for your Epson product as they may be needed for this new operating system.
Good Luck.
Nov 03, 2009 | Epson Stylus Color 777 InkJet Printer
Got a snow leopard udate on my mac. Also have a Z2400 series lexmark printer how can i get a update on the drivers
Generally if your printing postscript, you don't need to update the drivers on a Mac. But there are new drivers available for download on the website here. that said, there is not any difference between the Tiger, Leopard, and Snow Leopard versions of the driver...or much difference in the Linux driver for that matter. If what you have works, don't obsess over upgrading. They all work.
Oct 02, 2009 | Lexmark Office Equipment & Supplies
Need driver for Apple Snow Leopard with spc210
Ricoh directs all users to Apple to review this link (below)to determine if their Ricoh printer meets Snow Leopard compatibility.
Ricoh Printers Supported for Mac OS X v10.6
If you find that your printer is on the supported list,
then you can download the driver software for Snow Leopard on the Apple Support site.
Here is the Apple Support Link:
Ricoh Printer Drivers for Mac OS X v10.6
If you do not find your printer is supported, then unfortunately this driver download will not work for your printer in Mac OS X Snow Leopard.
Regards,
-Mactechtrainer
Sep 28, 2009 | Ricoh Aficio SPC210SF All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
43 people viewed this question
old marine
old marine
