Question about Microwave Ovens
Ice crusher and cube maker don't move when buttons pushed
  • Joseph Foley Sep 09, 2009
    it is the ice crusher which is defective not the ice maker
    the ice crusher and cube release do not work. the ice maker works fine. getting cubes
    President:
  • 2,777 Answers
Did they used to work just fine? What is the make / model number of the unit we are working with here?
Thanks
Tim
Posted on Sep 09, 2009
    Top Expert:
  • Microwave Ovens Master
  • 76,846 Answers
You will need to access the motor of the ice maker and activate the control, then see if the motor is getting power, if it is replace if it is avil separate from the ice maker unit, if the motor seems ok then the control pad is defective and you will need to replace that.
I have a Kenmore refrigerator model#106 56562400 and my icemaker is not working.I cleaned my refrigerator on 8/24/11 and since then the ice maker has stopped working.My refrigerator settings are as per...
Is the arm (on/off) switch down into the tray? You may have moved it up during the clean operation and inadvertently shut down the ice maker. Your temps are perfecto.
Sep 23, 2017 | Kenmore Microwave Ovens
Ice maker not making ice and doing lots of creaking noises
ice caught in release if u see piece or full cube remove can also tap side of unit usually releases what is in way
Jun 28, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Feb 05, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Mistral super slushie maker user manual
omg..i jist got a minstral super slushie maker..and man it jist doesnt figure,cant make the slushies..how does it work,,put ice cubes and rock salt and lil water in the ice hole and turned on mix switch and then pored cordial in the back of lid,,all read from the instructions and let spin for 15 minutes,,and nothing three times,,dumb founded,wat the???
Nov 06, 2010 | Microwave Ovens
I need a new lid for my Breville stick with ice crusher attachment. Model BSB600 serial no. 526. The lid attachment for bowl attachment is broken.
You can get this part only From Breville. So contact the sales/serrvice dealer close to you and get the details to order for a replacement.
Sep 06, 2010 | Microwave Ovens
I have a CEM Global PS78121 ice maker that has quit making ice after one month of use. I don't have a manual to trouble shoot it and need help. The compressor won't keep running to freeze the ice. Then if...
The problem is that the tabs on your white plastic tray with the ice falls into our broken off. I have the same problem. I am looking for a source to buy the new ice tray. If you have any knowledge of where to get parts for this piece of junk please let me know.
Aug 31, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
