Question about Refrigerators
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
  • 93 Answers
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Posted on Sep 13, 2009
Temperature control in fridge is turned all the way down but still too cold-25*, freezer=10*. What can i do? Amana SZD27ME side by side
Turning down the dial is not recommended as it does not turn the temperature down. Please return it the factory setting. If your temperature is too cold in the fridge, it may be the timer or thermostat. If it its in the freezer, it's the thermostat. If it both, you have a bigger problem, such as the compressor may be malfunctioning.
Jan 13, 2015 | Amana Refrigerators
Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
Oct 08, 2008 | Refrigerators
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Fridge acting as freezer
It's probably a bad thermostat. Is the compressor running all the time? When you turn down the 'stat does the compressor motor turn off? -Yes to any of those questions would indicate a defective thermostat -Stuck contact.
HonestDan
Jul 02, 2009 | Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Fridge Feezes
My Candy fridge freezer done the same. After a bit of investigation, I found that the little plastic shaft from the front temperature dial that connects to the thermostat has snapped. I merely glued it back together and it worked fine.
In essence, the thermostat was turned on to super all the time, and turning the dial anti-clockwise did nothing as it wasn't connected to the thermostat.
Very flimsy I say.
Apr 08, 2008 | Candy CPCA240FFK Bottom Freezer...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
265 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
