Emtron AC supply fault, but its work proper on battery, Please give suggestion. thind.beant@gmail.com
    Scholar:
  • 64 Answers
I think you have a componet failure, like a fuse that is blown, or a PTC is blown.
Posted on Sep 11, 2009
Error code ac
check startup sequence, at what stage you reach the fault?
Dec 12, 2013 | MGE Computers & Internet
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Phone restarts automatically
SOFTWARE FAULT FLASH UR PHONE.
IDRISH 911
Oct 25, 2010 | Nokia 3109 Cellular Phone
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
Hp530 power on password prblem
The reason why your password is still re-curring after removing the CMOS battery is because when you were doing so, some of the cables supplying power to the Board were still plugged.
So before using the CMOS removing method, first make sure that you have disconnected ALL source of power supply cable from the Board, then remove the CMOS Battery for a few seconds, and re-insert it. It should work like that.
Jul 09, 2009 | HP 530 Notebook PC
Travelmate dont switch on when i connect my adapter. even no led glows when the adapter connected. tried a new adapter still not working send me ur valuable suggestions to sheku1984@gmail.com
Remove your pc battery and try connecting directly to AC supply via your adapter. If you have a multimeter, you could measure your adapter's potential difference to be sure of the right voltage output ok. If nothing happened here, then you should open the pc's RAM compartment and remove the RAM(s). Re-install them properly and test one after another. You could also get a fully charged compatible battery and test alone, ie, without AC this time. If all these didn't work, then the culprit is the power unit. Good luck.
Jun 10, 2009 | Acer TravelMate 2300 Notebook
Battery not getting charged-power supply on ac power
hi thanks for using fixya!!
Is your laptop is brand new? Try to remove the battery. Then, try using your laptop and AC adapter without the battery, you will get the power supply directily from AC adapter. If it works properly, then its okay. Now, try to install back your battery then try to charge it. If not charging, perhaps you need to buy a new battery. However, I suggest you bring your laptop to a service technician to further check the error, before you purchase a new battery.
If you need further assistance, let me know!
May 25, 2009 | Computers & Internet
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
