Question about Acer Aspire 4520-5582 Notebook
Make connection between 2 laptops - Acer Aspire 4520-5582 Notebook
    President:
  • 1,187 Answers
If both laptops have WiFi ... configure them for "Ad Hoc" connection.
One laptop will be the "master" ... the other (or several) can connect to the master. Doesn't matter which is the master.
Another way is via a special USB cable ... from RadioShack ($30)
Another way, if both have internet, is to "Allow Remote Assistance invitations", but this gets complicated and may not be what you want.... Anyway, right-click "My Computer" and select "Allow Remopte Assistance..." in the "Remote" tab...
If you are simply trying to transfer files, you might use: email or a flash drive...
Hope this helps!
Posted on Sep 09, 2009
I am connecting 2 dell laptops and need to designate one as a master and one as a slave, how do i do this? thanks
You are connecting these 2 laptops HOW? Are you using a Data transfer cable? Are you connecting using WiFi? There is no master and slave unless you are connecting 2 hard disks.
Nov 01, 2013 | Dell Computers & Internet
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
I cant connect my cell to internet through connecting to laptop.i wnt 2 connect 2 internet via laptop by using my ph as a modem
You may find problems with that. BlackBerry now have stopped that feature on their software as it is being abused.
Speak to your local Phone Shop for advice.
Jan 23, 2011 | Computers & Internet
Two problems: 1) Fan keeps running 2) Can't
1.The fan should run as long as the laptop is on to keep your laptop's internal components cool.
2.Try uninstalling and reinstalling the printer driver
Dec 19, 2010 | Lenovo G560 06793JU Notebook
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 19, 2010 | 3Com OfficeConnect Router
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
(1) How do I connect to my internet with my
1.In order for you to connect to the internet through your wireless acer laptop, you should first prepare your laptop to accept wireless connections in order for you to set the proper settings. On you network configuration under the TCP/IP settings where you put the Ip address, you should set it to dynamic because when you connect to another network, the router should give you the ip address in order for you to connect to the internet.
2/ In order for you to charge your acer laptop, you should have a power adapter in which you connect it from your laptop going through a power source. And also you should have the correct Power Configuration in order for you to charge your laptop, you should set the right power schemes as Portable / Laptop.
Jan 20, 2010 | Acer Aspire One PC Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to support.dell.com and enter your service tag/laptop model # if you want).
Jun 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Acer Aspire 4520-5582 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
