Question about Westinghouse LTV-27w6 27 in. LCD HDTV
I have a Westinghouse LCD TV model LTV 27W6 HD. TV is 1.5 years old and once TV it turned on everything works fine. After 10 - 15 minutes of operation the video changes to colored horizontal lines. The audio continues to work fine it's just the video issues. Turnig the TV off overnight will reset the condition.
  • 360 Answers
This resistor in conjuction with large electrolytic capacitor is responcible for the internal filtering of the high voltage side of the board. As your unit heats up( anywhere fron 5 to 30 mins) you will notice horizontal flickering and prior to that red or green or even purple pixelation. Check this 1/4 watt resistor for dark discoloration and or a bad solder joint on the solder side of the board. This resistor is directly responcible for controlling the bias current to the high voltage regulators for the 160 volts DC. At no time should you handle or troubleshoot this board with the line plug in.
Even when this board is powered down that capacitor still holds a charge for up to an hour and can knock your you know what
in your sock. If you do not feel comfortable please take the board to someone else. Hope this helps
Posted on Sep 16, 2009
    Problem Solver:
  • 12 Answers
TV should be looked at by a qualified technician. The problem could be in the Power Supply PCB, Main PCB or Tcon PCB. Using cold spray is the quickest way to determine which board is faulty.
Posted on Sep 09, 2009
My Westinghouse LTV-w1 will not turn off. None of
try unplugging tv to reset it,leave it off for a minute,and then plug in
Jan 08, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse LTV-27w6-HD picture is scrambled periodically
Before you bother to read the text below, you might be better served looking at this thread:
Westinghouse troubles
If you aren't nauseated yet, continue with my original reply:
If the picture seems 'pixelated,' broken up into randomly sized and placed blocks, then it is losing synchronization with the digital signal coming in. This is certainly repairable and may be due to lousy assembly quality rather than a failed part. Most of our modern sets are assembled by robots but there is a degree of manual soldering still to be done and this can result in 'cold' solder joints that can fracture and fail due to heating and cooling of the innards of a set.
Unfortunately, unless you have a semi-retired TV service man in your neighborhood who is already financially independent, the labor costs could run fairly high for this kind of service since it requires methodical searching of the circuitry and could eat up some time.
Jul 24, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse lcd 26 inch
I found that with my Westinghouse SK26H240S lcd tv. that when you turn down the blacklight feature you get a hum thru the audio. so I just turned the blacklight feature to the max and the problem went away, no more audio hum.
Sep 11, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
42" lcd flashes picture
problem in the hdmi source......
Jun 03, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
572 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
