Question about Canon PIXMA MP830 All-In-One InkJet Printer
Purchased 2006. Excellent operation till now. Will not turn on. On/Off switch seems dead. Connections, CDRom install repeated and observed with close attention several times.
  • steinman156 Sep 09, 2009
    Thanks for the prompt response, Mr. K,
    I will ask my local repair man to check the power cord.
    How do I check a "power code"?
  • 4,281 Answers
First check that power cable is working fine .
sometimes currupt power code create this problem.
so change power code.
Also try with another power outlet.
If still problem remain you have to check circuit of printer.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 09, 2009
  • you can check your power code if you have other device which has same plug.
    Or you need to get that code from nearest shop.
    Thanks.
Have a 2006 vtx1300c dead nothing works battery is 13 volts
Sounds like a wiring problem. I would start at the switch and go back to the starter checking all connections especially the ones you replaced.
Nov 02, 2015 | 2006 Honda VTX 1300 C
I have a 2006 Chevy uplander, 3.5l, and when I turn the key to on position only the check engine symbol light's up on the instrument cluster and when turning key to cranking position nothing happens.
This is what would be done at the dealer or any good repair shop !
Perform the following preliminary inspections:
Ensure that the battery is fully charged. Refer to Battery Inspection/Test .
Ensure that the battery cables are clean and tight.
Inspect for any open fuses.
Refer to Power Distribution Schematics and Electrical Center Identification Views .
Inspect the easily accessible systems or the visible system components for obvious damage or conditions that could cause the symptom.
Ensure that the grounds are clean, tight, and in the correct location.
Refer to Ground Distribution Schematics and Power and Grounding Component Views .
Inspect for aftermarket devices that could affect the operation of the system. Refer to Checking Aftermarket Accessories .
Search for applicable service bulletins.
Did you find and correct the condition?
System OK
Go to Step 2
Install a scan tool.
Does the scan tool power up?
Go to Step 3
Go to Scan Tool Does Not Power Up
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to establish communication with all of the control modules on the vehicle. Refer to Scan Tool Does Not Communicate with Class 2 Device for the modules you should expect to observe.
Does the scan tool communicate with all of the expected vehicle control modules
Important:
To ensure that retained accessory power (RAP) mode is inactive, if equipped, open the drivers door during the following step.
The engine may start during the following step. Turn OFF the engine as soon as you have observed the crank power mode.
  1. Access the Power Mode parameter on the scan tool.
  2. Rotate the ignition switch, operate the ignition mode switch, through all positions while observing the Power Mode parameter. Refer to Body Control System Description and Operation for a list of the power mode states that correspond with each switch position.
Does the Power Mode parameter reading on the scan tool match the ignition switch position for all switch positions?
Go to Step 5
Go to Power Mode Mismatch
5
Attempt to start the engine.
Does the engine crank?
Go to Step 6
Go to Symptoms - Engine Electrical
Turn the ignition to the START position.
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Verify that the transmission is in Park or Neutral.
  4. With a scan tool, observe the IMS parameter in the powertrain control module (PCM)/engine control module (ECM) data list.
Does the scan tool display Park or Neutral?
Go to Step 4
Go to Range Selector Displays Incorrect Range
  2. With a scan tool, observe the Starter Relay Command parameter in the PCM/ECM data list.
  3. Turn the ignition to the START position.
Does the scan tool display Yes?
Go to Step 6
Go to Step 5
With all the modules on your vehicle you really need to start with a professional grade scan tool to see if all are communicating .
Aug 17, 2015 | Cars & Trucks
My car does"t want to start. It has a new battery. Had to towe it home. Replace starter. After the second attenpt to turn it on it did. Turned of and a minute later did not start. What can be the problem ?...
Could be a bad or loose connection on the battery.
When you're trying to start the car, turn on the headlights. If they dim or go out, the problem is the battery or battery connections.
Hope this helps.
Mar 28, 2015 | 2007 Honda CR-V
2006 chevy trailblazer dome light will not shut off
There is no fuse marked for dome light's in the rear fuse box. The BCM - body control module controls the dome / courtesy light's .
The body control module (BCM) monitors the courtesy lamp switch signal circuit in order to determine when the courtesy/dome lamps should be illuminated. When the BCM senses that the courtesy lamp switch signal circuit is grounded when the switch is activated, the BCM will directly illuminate the courtesy/dome lamps.
DTC B3801 Passenger Compartment Lamp Request Circuit
You should possibly think about taking your vehicle to a qualified repair shop !
With a scan tool, observe the courtesy lamp switch parameter in the body control module (BCM) data list.
Does the scan tool display INACTIVE?
YES - Go to Step 3
NO - Go to Step 4
Activate the courtesy lamp switch.
With the scan tool, observe the courtesy lamp switch data parameter.
Does the courtesy lamp switch data parameter change state?
• Test the courtesy lamp switch for sticking in the ON position.
• Perform a visual inspection for loose or poor connections at all related components. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Nov 24, 2017 | 2006 Chevrolet Trailblazer
2006 Porsche cayenne trunk will not open.
Emergency operation of rear lid
If the rear lid cannot be opened with the radio
remote control (e.g., if the battery of the remote
control is dead), the emergency operation must
be performed:
1. Unlock and open the driver's door with the
vehicle key.
2. Switch on the ignition so that the alarm system
will not be triggered.
3. Check if the TAILGATE function is activated in
the multi-purpose display of the instrument
panel.
Please observe the chapter “TAILGATE” on
Page 119.
4. Press the central locking button in the armrest.
The rear lid is now unlocked and can be opened
with the unlocking handle
Jul 03, 2009 | 2006 Porsche Cayenne
My system does not recognize my external cdrom drive though they are of the same brand
Sir,
It is problem with Operating system or drivers. Go to control panel, click the icon system, go to hardware tab, go to device manager, check the listing of cd/dvd drive below it something like yellow with exclamation mark. U should not install the driver. so reinstall the driver and install it
Thanks Good Luck
Appreciate to rate as "Fixya"
May 21, 2009 | Dell Latitude D410 Notebook
Everything turns off when I hit the start switch.
Sounds like poor connections on the battery.
TL
Jan 23, 2009 | 2001 Ducati 748 S
Key won't turn
You are very welcome, glad to help.
Now, since you know "how to release it"; here is a tip: Turn the key off, and pull it out. Turn the wheel to the left, and wait for it to lock. Observe where it locks. Unlock it, and repeat the procedure, turn to the right. Observe again. Now you will know where the wheel locks, and if you avoid having the wheel close to those locations, the wheel will never lock on you again!
The graciousness of a FixYa rating for my assistance would be greatly appreciated.
Thanks for choosing FixYa.
Dec 09, 2008 | 2006 Toyota RAV4
Canon PIXMA MP830 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
