Question about Garden
Florabest branch cutter...where can i buy a spare model kh 3127
Fl
orabest branch cutter...where can i buy a spare cutting wheel
model no. kh 3127 9.6 volt ...made by kompernass
2 Suggested Answers
goldenglove1
  • 144 Answers
SOURCE: Motor stopped working (apparently burned
Well, at this time I would say buy another one, because no one takes the time to take these things apart and sell them. I am currently working on a website which just sells the parts needed to fix things like that, but it will be a while until I get the web site in circulation. I suggest buying gas powered hedge trimmers for thick shrubs.
Posted on Aug 14, 2010
I need foil and cutters for SP 7300 and SP7900.I live in Durban, have you a branch where ni can buy these items.Gerrie.
we here on FIXYA have no idea as to where you can get said items , we have no branch's that sell any products
Feb 02, 2017 | Health & Beauty
The tip of blade will not come together or close.
if it is a hedge trimmer as per the catagory, get a new cutter bar or get a new hedge trimmer
probably from blunt cutters that tried to cut too thick branches
if it is secateurs then do as ray suggests
Oct 02, 2015 | Garden
How can you buy just the saw for the 8" 2 in 1 pole saw.
after looking at reviews written on
http://www.chainsawsdirect.com/Earthwise-CVPS41008-Chain-Saw/p7224.html
Robert
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Shawn
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
Jul 07, 2014 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
I have a Milwaukee CP12 12V Pipe Cutter. How do I change the cutting wheel?
I don't own pipe cutter but I have band saw. Just so easy to replace its consumable parts. Check this link . Hope that helps.
Apr 27, 2013 | Saws
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
What is the difference between a pizza wheel cutter and a pizza rotating knife?
A pizza wheel cutter is a metal wheel that rotates through the pizza so you can cut it even when it's hot. A pizza rocking knife is a thick metal blade with handles that you can use to rock backwards and forwards through the pizza to cut it.
Jan 10, 2013 | Home
How do i cut my shimano xtr hydraulic hoses to size?
You need spare olives (the brass ones are best) buy on Chainreactioncycles.com, measure your hose and allow for bad cut first time so add a Cm to measurement you can cut away just make sure that you use really sharp cutter (I use craftknife) place hose on non slip surface and cut cleanly, push on olive and reattach and tighten
Mar 19, 2009 | Shimano Xtr Mountain Bike Dual Control...
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Garden Logo
404 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
