Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3t will not power on
Kenmore he3t model # 110.42922 200 front loader will not power on. Main circuit board out??
Bought this in 2003 this will be the fourth time this machine has has problems.
I have no idea on how to get to circuit board
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
WHERE CAN I DOWNLOAD A OWNERS MANUAL FOR A KENMORE WASHER
See either of the two following sites.
SEARS PARTS SITE MAY HAVE MANUALS
http://www.searspartsdirect.com/partsdirect/index.action
SEARS ANSWER SITE
http://www.managemyhome.com/
Dec 05, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Not a problem ... Just bought a Kenmore Elite HE3t washer & dryer and read bad evals on Sears.com.....are these good machines, or should I change my order?
I would send it back ASAP, had our Kenmore Elite front loaders for less than 2 years and it has been nothing but trouble, so far it has cost us $200.00 in repair fees and washer still not fixed, expecting another so called Sears expert out tomorrow that will be another $129.00 for just showing up without guaranteeing he will fix anything.i
Sep 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3t water fills by itself! with door open too! doesnt always drain fully
If you tip the machine back at an angle, you should see a clear plastic sausage shaped thing with a plastic tube coming from it, you will need to remove the plastic thig (pressure vessl) and clean it out.
Nov 30, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
A kenmore HE3t front loader MO. 11042932200
Suggestion: Plug off the wall first. Check to see if all the connections are firmly pushed in; during the job some could hv come loose. Check the wall outlet, your washer plug....whatever. Then plug in.
Sep 21, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kernmore elite He3t
Well there is one of two control boards that is malfunctioning, most common is the Machine (or Main) control board, there is also a display pc board in the control panel, but i have had few problems with that control. Unfortunately the main board is $300.
Sep 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
213 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
