We have problem with mitsubishi projection tv 65 " serial no 115480 model no.ws 65869,we had power lost for two hour when power came back tv was not coming on. on front panel timer green light stays on,does not go away,we have tried few times pluging and unpluing but it did not work,please help.
  • 68 Answers
You have a dm board problem, there are some caps on the dm board that need to be replaced.
Posted on Sep 10, 2009
I have mitsubishi 65" platinum series plus tv model WS-65869. the power green light continues to blink for three days know, and will not reset.
I am assuming the television is not powering up and the only thing it is doing is showing the blinking green light.
Unplug TV from the wall and see if it will reset itself.
If unplugging doesn't fix the problem then you need to find out what is causing problem. First thing to check are the fuses. Second thing to check is looking for burnt resistors or bulging on top of capacitors. Something caused the TV to enter so called safe-mode.
TV's carry alot of voltage in them so BE CAREFUL and UNPLUG THE TV.
If you are handy with a soldering iron then you can save yourself alot of money. An average service call & repair is $300-$450.
Oct 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Picture is completely out of alignment, went to do
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Dec 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Color is going weird
Chroma IC is to blame, but before you go replacing it, be sure that the power supply voltages are correct....accordianman
Jun 05, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
