Question about Refrigerators
Auto defrost causes vegetables and fruit to freeze - also drain hole freezes up
  • 11,896 Answers
Auto defrost timer may need to be tested or replaced.
sci.tech-archive.net/pdf/Archive/sci.geo.../2009.../msg00012.pdf
Posted on Sep 09, 2009
How to freeze avocados
try doing an avocado puree before freezing it, lasts longer and tastes better than freezing the whole avocado fruit.
Dec 11, 2013 | Cooking
Freeze whole avocados
you can. though the texture will likely be compromised once defrosted. avocado mash freezes better.
Dec 03, 2013 | Cooking
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Kenmore top mount refrigerator auto defrost is pooling water below vegetable bin and not in the defrost tray. lines are not plugged
the drain in the freezer is plugged,you need to remove the inside freezer wall and melt out the ice and clean out the drain line,i use a steamer to blow out the line,when you think you have it cleaned out pour hot water down the drain,if it goes down then you know it's clear,also there's a heater probe you can buy that connects to the heater and you stick the other end of probe down the drain hole so it can't freeze up again
Mar 15, 2010 | Kenmore Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water is collecting under fruit and vegetable bins and then leaking out onto kitchen floor.
sounds like a problem with defrost drainage system. would need model #. older GE refs had problem with rust holes in drain trough. how old is it? do you see any rust on back wall of ref? newer refs had problem with drain hole freezing shut and heat probe had to be installed to prevent it from freezing shut.
Jan 05, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Water running out from under vegetable and fruit
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Hook the other end , around the glass rod (defrost heater) carefully , to avoid breaking the glass , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 01, 2010 | Refrigerators
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
