Whirlpool Duet GHW 9400PL0
I am not sure if my last email worked so I will resend. I found a wire with a spring inside of my washer after completing a load of laundry. I believe it is part of the boot seal and have attached two pictures. Do you know how to reinstall this part.
Thanks in advance for any help you can provide.
Chris
  • suzyshrink Mar 23, 2008
    I have the same problem - did you ever find a solution?
Hi, the wire looks like the one that holds the rubber door seal in place on the washer drum , if it is then its important it goes back as the rubber could come of. Have a look around the seal. cheers Rick
Posted on Mar 05, 2009
I just had the very same problem - HELP!
Posted on Mar 23, 2008
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
F2 PROBLEM
in google search bar ,type (whirlpool ghw 9400 duet fault codes),
then clic on (whirlpool duet intro)
(https//secured whirlpool.co.service) this should give you a good description of the machine
Jul 30, 2011 | Whirlpool GHW9400 Duet Washer
Whirlpool duet model # ghw 9400 lo.door locking problem.
One hour service plus $40 part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 14, 2010 | Whirlpool GHW9400 Front Load Washer
Help! im looking for a manual for a whirlpool awm 293-600 and also maybe a close up picture of the cycle dial as some of the settings have rubbed off?
I am not sure about the awm 293-600 number, but under the ghw 9150p (under your picture) I found one here..
There is a nice picture of the dial settings too.. I hope this helps you. Let me know...
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet GHW 9150P has code f11. what do I need to check
I would open your bottem panel. There should be an owners/service manual in the inside of the battom panel somwhere. If not on the botton, slide the top panel off and check along the inner side walls for a service manual. These usually have the error codes and descriptions.hope this helps
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Button start locked my clothes locked inside washer duet whirlpool ghw-9200lq
If you suspect you have a defective door latch, you should be getting an error code of "Fdl" displayed on the console as well. This may just be a matter of a malfunction where the latch became jammed. You can still get your clothes out of the washer by removing the lower panel under the door. There are 3 torx type screws under the bottom edge of the panel. After removing the panel, place your hand inside the washer behind the front casing where the door latch assembly is. Try to locate a plastic tab at the very bottom of the door latch and pull straight down. This is a manual door release and the door will open, allowing you to retrieve your clothes. With the door opened, try closing it again. Select a wash cycle and push start. Listen to see if you can hear the latch lock. Push PAUSE/CANCEL to stop the cycle and listen to hear if the latch unlocks when the cycle stops. If you definitely have a defective door latch, follow these steps to replace it:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
NO SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Feb 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW 9400P
Hello! your problem is the motor control unit,MCU.
or the central control unit,CCU. Try unplugging the washer for a few minutes sometimes that will reset the unit.There is a tech sheet inside bottom of the washer cabinet.If youre not sure, may need a service tech.
Dec 17, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
