Question about Toshiba 50HM67 50" HDTV
Recently replaced blown lamp for 50HM67 50 inch tv. Now have picture but clarity is off. Picture / screen words are very blurry. Toshiba referred a local repair company who mentioned that the problem seeded to be the conversion needing to be adjusted. To save spending on retail repair fees, can the conversion be adjusted at home? If so, how do you do that?
    Problem Solver:
  • 12 Answers
If the picture was good before the lamp blew, there might be dust/splatter on the window in front of the lamp. Pull out the lamp assembly and look at the small square glass window that the light shines into. It should be clear and clean. If it is not, clean it gently with isoprophonol alcohol or screen cleaner.
By the way, there is no such thing as convergence adjustment on DLP TVs.
Posted on Sep 09, 2009
  • chrisnrandi Nov 03, 2010
    The small square glass has a smooth side and a not so smooth side are they directional, meaning does it matter which way put back in?
Why is picture blurry?
Sounds like a misalignment problem. the lens has a specific optical plane the DLP chip must be positioned at in order to provide the proper focus on the screen. Try repositioning the board or adjusting the lens to clear up the fuzzy picture. Regards.
Aug 17, 2015 | Mitsubishi WD-73733 73" HDTV
Blurry picture
CONVERGENCE MAY BE THE PROBLEM. FIND HONEST TV TECH
Nov 12, 2013 | Toshiba 56MX195 56" SDTV
Ok here you go, I needed to replace my lamp on my Sony KDF-50E3000, lamp XL-2500. Easy replacement, however now only the picture is HD and any words, at the bottom of the screen are blurry. The blurr...
Only getting HD has nothing to do with a lamp change. I would start by seeing if your antenna settings got changed. For example from cable to over the air antenna. As far as the blurry words on the bottom of the display, I think you didn't get the screen lined back up all the way.
Apr 05, 2011 | Sony Televison & Video
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Toshiba 50HM67 50" HDTV Logo
318 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
