Question about Briggs & Stratton Garden
I am looking for a service manual for a gas powered craftsman pressure washer 2000 psi 3.75 hp. Cant seem to hook it up correctly
    President:
  • 704 Answers
If you have the product model number (located on the tag on the unit) you can follow the attached link and enter in your pressure washer model and then look to the right side of the page and click on the "manual" button to get a copy of the manual you can print or download for free.
Here's a link to a gas powered Sears pressure washer to get you started.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=919762350&productCategoryId=1505000&brandId=0247&modelName=PRESSURE-WASHER&diagramPageId=00001&componentDescription=REPLACEMENT%20PARTS&documentId=10060725&backToLink=Return%20to%20Sub%20Components%20list#partLst
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
    Sergeant:
  • 384 Answers
Get the 8 year old neighbor kid to help you.
Cant find choke on craftsman 2700 2.3 ready start 7.75
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
New 75219 Power Washer is missing owners manual.
Any luck finding someone to give you a copy of the manual for this model? I bought one on clearance and it doesn't have the manual and I'm scared to even start it up without reading the manual as I don't want to mess anything up upon first start. If I ever do find one, I will post a copy of it for you. Good Luck! Thanks
Jim
May 27, 2010 | Craftsman 2500 PSI Briggs Stratton...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Garden Logo
293 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
