Question about Hotpoint RB757 Electric Kitchen Range
We took the oven door off and now can't put it back on
Cleaned the oven totally today, but can't get the hinges to set right to reinstall the door. HELP!
we took the door off, but the hinges are retracted into the door and we cannot get them back out to engage them in the range slits/pins.
  • 6 more comments
  • cjcurtis Dec 18, 2007
    I took the door off of a gas stove and cannot get the hinges back in they will not stay locked out. As soon as I pull them out they slam back in. I don't see how they will get back on the oven unless they are fully out and they will pull out somewhat but they won't stay.
  • kitchenhelp Dec 22, 2007
    I was moving my oven to clean under and behind it.  The door came off at the left hinge and the hinge is locked in the door.  I can't pull the hinge out of the door in order to attach it back to the oven.  Help!
  • Anonymous Feb 27, 2008
    cannot get oven door back on,
  • Anonymous Apr 05, 2008
    took the oven door off to replace the element, now we can't get the door
    back on
  • murielc Jun 08, 2008
    We removed the oven door along with the hinges, before, reading the book to leave the door in broil position to remove it. Now we can not get the hinges to move after inserting them back in thier places on the stove. The hinges are fully open and we have tried with and without the door but they will not close, they seem locked in position.
  • Anonymous Jul 13, 2008
    Can replce oven door
  • Anonymous Aug 14, 2008
    I hkave a stoves oven the door does not close flush the seal is ok but I think that the hinges need adjusting but I am unsu8re how to take the door off. to get to the hinges the door opens downwards
  • trey123 Nov 04, 2008
    i cant get my oven door back on and i dont now how to lock it
  • 126 Answers
I dont know how you got the door off the is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off
Posted on Dec 10, 2007
    Novelist:
  • 123 Answers
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Posted on Feb 13, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 13, 2008
    Was this solution helpful? Show your Appreciation by rating it:
Oven door hinge
Could you take a photo of the oven, the door and the hinges and show us?
Feb 14, 2014 | GE Microwave Ovens
My oven door glass was dirty, from the vents in the oven door..so we took off the oven door, took apart all the screws and cleaned the glass. First of all, don't know if we got the glass pieces in the...
the glass pieces should only fit back in one way, holes will only go one way , as far as the hinges, the need to be locked open in order to replace back into the unit, there is either a small hole in corner of hing that when pushed wll align with another hole in hing allowin for a thin blade screwdriver to be inserted adn hold in hte locked position,... the other way is a small locking mechanism is loacated on the top of hinge that when fully extended will lock hinge open for reattachment... you would need to REALLY PRESS that hinge to lock in place..
Oct 09, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door won't go back on
well there is one where u have to put a pin through the hinge to lock it in a certain place to remove and reinstall it..kinda tricky. locks it in the semi-open position. others have pieces that swivel down to lock the hinge in that position for removal and reinstall. it's not easy if you've never done it. :)
Jun 13, 2009 | Kitchen Ranges
Reinstalling oven door
be exstreamly careful do not put your fingers near the hinge. somehow pull the hinge apart till the stay open and you may see a hole in it, put somethjing like a nail into it to prevent it from snapping closed. then put it into the slots on the oven till they are in the right position then open the door all the way and then just pull out the nails. That is if it is that type of hinge.
Oct 30, 2008 | Roper FEP320 Electric Kitchen Range
Whirlpool oven
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong
Oct 25, 2008 | Whirlpool RBS245PDS Electric Single Oven
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Cleaned the door but can't get back in
It may take two people but if you pull the hinge open there should be a small hole in it. It should of had some pins in the bag if you got it new. If you don't have them find some short pins, screws or nails that will hold the hige open so you can reinstall it. Once you get the door back on you should be able to open it all the way and take the pins out.
Apr 17, 2008 | Whirlpool RBS245PDS Electric Single Oven
Hotpoint RB757 Electric Kitchen Range Logo
1,616 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
