Question about Kodak EASYSHARE 5100 All-In-One Printer
Bad color results do I need a new printhead?
Bad color results do I need a new printhead ? Hardly any blue shade
I have a 5100 AIO CN3J9338-7324076G07
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Same on kodak...
Just try cleaning the printhead using the AIO home center program and i'm sure you would be able to restore good print quality again
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 aio; banding/streaking problem
You will need a new printhead. If its not under waranty good luck trying to find one.
Jul 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Prints only pictures and not text
Run the printer maintenance program and clean the printhead. If that doesn't fix the problem, contact Kodak support. If needed, they will exchange the printhead for a new one.
Feb 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AIO won't print after cartridge change
the red blinking light indicates that your printer wont recognize your ink carthridge. you can try to reseat the carthridge and the printhead. to remove the printhead just press on the release tab which is located on the upper left corner of the printhead wall. If this will not correct the issue, you need to call their technical support hotline. maybe the carthridge is faulty or there is a problem on the printhead. their hotline no is 1 800 421 6699
Jan 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Not printing
The option to clean the printhead is on the Kodak AiO Home Center, when you open it you need to click on the Question Mark (?) and then, under General Links, click on "Maintenance", then a new window pops up and you will see the option to clean the printhead.
Although, most likely it still won't work, so I recomend you to call Kodak AiO Printer support at  1-800-421-6699 to have your printhead replaced.
Nov 04, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color is all wrong
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Sep 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 printer
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Help
Sorry to hear about your problems. Here are the steps Kodak AiO Support will ask you to perform.
Close the printer.
Jul 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
